Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 01-12-2009, 05:56 PM   #1 (permalink)
Local Rotor Head....
ah64id's Avatar
More guages installed...
Over the last few weeks I went from 2 gauges, boost and EGT, to 6... I also made my dual a-pillar a single a-pillar.. The visibility is much better now.
I added Rail Pressure (for fun, I don't mess with pressure), fuel pressure, oil pressure, and drive pressure (mainly for exhaust brake pressure). I also moved my pryo probe to the collector and put the drive pressure in the old pyro hole..
I have played with the drive pressure a little, but nothing too much.. I will be curious how it runs when towing.. It gets to about 40 and holds with the WG on... over 55 with the WG off and stock fueling.
The Fuel Pressure sender. I "T"ed into the line after the Cat 2 mic and before the CP3.
The new pyro location and DP hookup.
6' of copper tubing to dissipate the DP heat.
Inline filter to keep any soot (in case of an air leak) from getting to the gauge.
Where I tapped into the oil.. On the drivers side above the ECM.
Rail, Fuel, Oil
EGT
Drive, Boost
ah64id is offline   Reply With Quote
Old 01-12-2009, 05:59 PM   #2 (permalink)
Banned
Ignore my post in the Efficiency thread...LOOKIN GOOD! I need to get myself Oil Pressure now...damn you!
awenthol is offline   Reply With Quote
Old 01-12-2009, 06:01 PM   #3 (permalink)
ah64id's Avatar
Haha.... yeah I think its a must have... really pisses me off they gave us and idiot gauge.
I have seen 58psi with the exhaust brake.. maybe I should have gotten the 0-100???
Old 01-12-2009, 06:03 PM   #4 (permalink)
lesbian at heart
elephantrider's Avatar
just curious as to why you didnt put the oil sending unit
on top of the oil filter housing .. ?
that oil pressure gage is electric right ?
i really like the overhead pods. looks killer.
did you have to get extensions to run those
way up there ?
jason
04.5 6sp qclb whiskey tango foxtrot, over
elephantrider is offline   Reply With Quote
Old 01-12-2009, 06:03 PM   #5 (permalink)
Northern CA Chapter President
Neel's Avatar
do you have room for anymore gauges lol.
2006 cummins 3500 laramie murdered out
13.5'' lift, 20x12's on 41'' iroks
TURBO ENGINEERING CORP. 617hp, stock cp3,stock lift pump, and on 41's
custom paint and amp step getting done
Neel is offline   Reply With Quote
Old 01-12-2009, 06:05 PM   #6 (permalink)
Banned
There's room for about 7 more gauges ...I'd prolly do single steering column, though.
Old 01-12-2009, 06:06 PM   #7 (permalink)
ah64id's Avatar
way up there ?
Yes, elec. Because with the gauge on the OH the sender wire is too short to reach over there.. so instead of splicing the wire I just used the port on the drivers side... I also think I may get a more accurate reading on where its at because my bypass is also using that 1/8" NPT port on the housing. I didn't have to extend anything, thou I am not sure the RP would fit all the way right
Yeah, if you do everything you can have up to 9, 12 on a 03-05...
I don't mind the double column.. I can still see the ODO and the cruise light, so its no biggie.
Old 01-12-2009, 06:07 PM   #8 (permalink)
Neel's Avatar
ah get a dual steering collom pod you can always find another gauge to put there.
Old 01-12-2009, 08:24 PM   #9 (permalink)
lesbian at heart
cool - i figured you would have length issues
with at least one of the gages. the harnesses
arent as long they should be imo.
jason
Old 01-12-2009, 08:25 PM   #10 (permalink)
ah64id's Avatar
They at least should offer a sender extension like ISSPRO does.
But I am happy with this install, it was more work but its in.
Old 01-12-2009, 09:00 PM   #11 (permalink)
Diesel Poser
slagburn's Avatar
Does that 0-100 gauge over the mirror say fuel pressure? I assume that it is the oil pressure gauge...
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21
slagburn is offline   Reply With Quote
Old 01-12-2009, 09:05 PM   #12 (permalink)
ah64id's Avatar
Yes it does, and yes its oil. Pricol does not have an optix oil pressure gauge.. they plan to change that gauges face plate to say oil, but still haven't.
