Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 12-23-2008, 09:09 PM   #1 (permalink)
Quaticman's Avatar
programmers-how do they work?
It is my understanding that modules/programmers either alter the pressure, timing or duration or a combination of each. Is there anything else they do to increase performance?
03 2500 4x4 RC 5.9 SO; 47 RE billet; ATS flex plate; SMARTY Revo-TNT/Dr. P; BD Super B turbo/exhaust manifold/IC boots; Devils Own; Air Dog; K&N CAI; S&B; MBRP 4"; Mag Hytec; Auto Meter C2 gauges; Quad BF/RP gauge; Fluidamper; rail capped; 455 HP/852 TQ.
Quaticman is offline   Reply With Quote
The Following User Says Thank You to Quaticman For This Useful Post:
natas01 (09-02-2009)
Old 12-23-2008, 10:45 PM   #2 (permalink)
what more can you do?
In reality there are a limited number of ways to increase HP in a diesel.
1. increase the fuel pressure, thus more fuel enters the chamber in the short time the injectors open.
2. Increase the duration. Increase the time the injector flows fuel into the chamber.
3. Change the timing. Alter where during the stroke the fuel is added. By adjusting timing you can increase mileage by injecting the fuel sooner. This increases cylinder pressure, gives a more complete burn in the chamber, decrease EGT's, but will increase turbo lag.
By retarding the timing, EGT's go up, cylinder pressures go down, Turbo lag decreases and more fuel is consumed.
The main trick would be to find the best combination of the three to accomplish whatever goals you have.
Some programmers also control the electronic wastegate, and will allow you to run a little more boost to allow the use of the extra fuel. However more boost does not always produce more power, because once the turbo gets outside its efficiency range, the usefulness of the air is decreased.
Is that what you were looking for?
2007 2500 QC 4x4 5.9L
Just a wee bit more than a stock truck has!
Twoforme2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Twoforme2 For This Useful Post:
cmns2500 (10-26-2009), crimbshaw188 (10-25-2009)
Old 12-23-2008, 11:39 PM   #3 (permalink)
Quaticman's Avatar
thanks for the explanation-that is exactly what I was looking for
Old 12-23-2008, 11:44 PM   #4 (permalink)
Super Moderator
dieseltracks's Avatar
Nice explanation Twoforme2..........I think I'll even put a sticky on this.
That's a good explanation for people who are just starting out in the world of "diesel bombing".
Dave
02 2500 QC Longbed 4x4--Goerend Triple Disk TC/VB/Flexplate/Billet input--VA/TST PM3--FTE 100hp injectors--BD 3-pc ported manifold--HX35--95gph HPFP--4" exhaust with a 7" blowhole
BE SURE TO CHECK OUT OUR CF SITE SPONSORS FOR ALL YOUR PARTS NEEDS!!
dieseltracks is offline   Reply With Quote
Old 12-24-2008, 06:58 AM   #5 (permalink)
bigcalidave's Avatar
Since this is sticky, maybe we could get a comprehensive list of the capabilities of all the programmers and chips/modules on the market? There are so many pucks, boxes, chips, monitors, programmers, etc etc etc that people can get easily confused. Then when you are considering a stack, you might end up with incompatible parts, or just parts that repeat the same adjustments!
If we could make a list of what each one does, what sensors it intercepts, and i'm sure there's more (it's like 3 am, I'm not fully clear right now ) I think we'd have a hit info source... It seems like guys here have a better knowledge of these performance parts than the companies that make them, at least what info they publicize.
For instance, I'm trying to figure out if I need a boost fooler in conjunction with my TST cr49 if I turn off the boost defueling setting on it? (if I upgrade the turbo)...
Mods, think we can change this all around?
Truck for sale!! Sad but has to happen!
http://www.cumminsforum.com/forum/3r...e-nor-cal.html
bigcalidave is offline   Reply With Quote
Old 12-24-2008, 09:25 AM   #6 (permalink)
fxwannabe's Avatar
There is a list on here somewhere but I can't find it.
04.5 2500 4wd, 6 speed, 3.73 gears Mods: 4" Superlift, 315/70/17 BFG A/T's, Silencer MIA, Thuren track bar, diPricol boost, egt, and fp gauges, Crazy Larry 330hp/620tq
<----- Getting a 12 valve when I get cash.
fxwannabe is offline   Reply With Quote
Old 12-27-2008, 04:24 AM   #7 (permalink)
I live for burnouts
blowerguy's Avatar
That's exactly what this place needs. I've spent hours researching on here with little posting - because I seem to ask the same questions and get the same answers...."just go buy a smarty" Well, I did - and it doesn't seem to work any better that what I've already tried. I'd say 80% of us on here are looking to spend $1500 total in performance parts while the other 20% have a money tree and are looking for 10's in the quarter mile with a 4 ton truck.
Obviously there are some guys on here that have earned their respect with knowledge. So why can't we "sticky" their findings at the top of the page so we don't have every tom, dick, and harry Newbie coming in here posting, "which tuner" for the 87th time this week.
I'd like to know what level 3 does on my edge juice/attitude - and have people stacked it with a timing tune on the smarty?
I think it would be great if the performance parts discussion was split down to some more sub catagories.
1) Tuners
a) tuners only
b) stacks
2) intakes
3) exhaust
4) turbos
and so on........
There's just too much info to weed through. If I look up smarty, I get a hundred threads just talking about it's the holy grail of tuners, and nothing about what it actually does. I had no idea the used smarty I got was "old" and needed updated until I talked with a GURU on the phone.
I'd like to see what kind of timing each one of these things add, and some form of calculating how much fuel each one adds. Whether it be 10% more fueling, or whatever.
Its been years since I knew how a diesel was timed, and even at that - these new engines I'm sure are totally different.
What is stock timing ?* degrees BTDC? ATDC? what does the smarty add on it's levels?
What timing is dangerous?
'05 dodge 6spd 2500 S&B stage II intake, Edge juice/attitude set on "0", (tried diablo predator), now trying out Smarty S06, Magnaflow, Mobil 1 synthetics, Looking for MPG's - work truck
'05 silverado 2500 whipplecharged 9PSI - fun truck
blowerguy is offline   Reply With Quote
Old 12-27-2008, 05:45 AM   #8 (permalink)
ynots57's Avatar
somewhere there is a list of programers that shows a side by side of what each individual programer alters. it was made for when stacking you wont have 2 programers trying to perform the same duties. ill try and find it and post it up
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 12-27-2008, 08:03 PM   #9 (permalink)
I live for burnouts
blowerguy's Avatar
any luck finding it?
Old 12-28-2008, 09:25 PM   #10 (permalink)
underramarmor's Avatar
Dodge Cummins Stacks - Google Docs
2005 Black Ram 2500 Auto, Edge Juice w/Att, Intake Manifold Horn, K&N Drop in, silencer ring MIA,Toyo Open Country A/T, Autostart Alarm, Blue Gauge Cluster, Hid solutions 6000k Hid Kit
underramarmor is offline   Reply With Quote
Old 12-28-2008, 09:47 PM   #11 (permalink)
Posting Suspended
Originally Posted by underramarmor View Post
Good link. How about one for 3rd gen trucks?
JDiepstra is offline   Reply With Quote
Old 12-29-2008, 09:38 PM   #12 (permalink)
I live for burnouts
blowerguy's Avatar
not enough info anyways. I would like to know what kind of timing each throws down.
