Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 12-29-2008, 09:46 PM   #13 (permalink)
kaiserbailey's Avatar
I don't see the TS performance MVP
'05 2500 4x4 QC/SB, 33" BFG AT, Ranch Hands, 5" Magnaflow TBE, Banks Ram Air Intake, Banks Intercooler, Banks High Ram Intake Manifold, Fass 150gph, Smarty, MP-8, FTE Rail Cap, Autometer Phantom II: EGT, Boost, Tranny Temp, Fuel Pressure, Fumoto Valve, Amsoil
kaiserbailey is offline   Reply With Quote
Old 12-29-2008, 09:46 PM   #14 (permalink)
lets give them at least a week before the great bd smarty debate is asked again
08 laramie mega cab 6.7 some goodies. 07.5 laramie quad cab some things fell off
torquey is offline   Reply With Quote
Old 12-30-2008, 02:06 AM   #15 (permalink)
skneeland's Avatar
Originally Posted by blowerguy View Post
not enough info anyways. I would like to know what kind of timing each throws down.
good luck, now you're talking proprietory info.
i would love to have such data (believe me, ive asked), but i doubt the manufacturers are going to give that out freely
06 Laramie auto,5" lift,35"ToyoMT/18"AR wolverines, airbags,ladder bars,Smarty,TST,DTT billet trans,MPItwins, HTTman, AFE, ARPstuds, 5"pipe, CFMintake, 2micFuel system & more... 98.5 QcSb sport 5spd,3" lift,35"ToyoMT,VA box,60hp stix
skneeland is offline   Reply With Quote
Old 01-20-2009, 08:50 PM   #16 (permalink)
Fuel76's Avatar
any luck finding it?
Just ordered Diablo predetor programmer today. I have intake and exhaust on order aswell. Did not know which programmer to go with. I am very new to performance tuning on the cummins 5.9L , My truck is a 06 2500 sport with 6 speed. Any body have any insight into the predator from diablo. Is it tune able on the fly. I could not get hardly any clear info from the web site. any help would be greatly appreciated. thanks!
Fuel76 is offline   Reply With Quote
Old 01-20-2009, 09:54 PM   #17 (permalink)
I would be very interested in seeing this spread sheet for a 3rd gen. If in fact the Ottomind only does fuel, then I would do very well to get something that does timing as well. It looks like some of the options on the 2nd gen sheet are not available for 3rd gen? Anyhow, that's a cool spread sheet. I wonder how much mileage/power could be added with proper timing adjustments to my current setup.
2004.5 QC LB 4x4 Banks Monster Exhaust, CFM+, Icebox, cool tube, Banks Ottomind
Cotharyus
http://cotharyus.net
cotharyus is offline   Reply With Quote
The Following User Says Thank You to cotharyus For This Useful Post:
pops77s (08-27-2009)
Old 02-27-2009, 12:06 AM   #18 (permalink)
chart showin which programmers are stackable 3rd gen?
Does anybody know if there is one available? I am new to the idea of stacking... I have looked all over on here and can't seem to find a bare bones explaination.. Any help would be greatly appretiated!!!
03 dodge edge attitude w/juice,banks intake,banks inner cooler,homemade cold air intake,4inch turbo back to 6inch miter cut stacks and a fass 150 fuel pump, westech fuel pressure gauge,, dually with auto trans
rasstus99 is offline   Reply With Quote
Old 02-28-2009, 01:50 AM   #19 (permalink)
has anybody used a flashpaq 3815 chip
PONCHOS05 is offline   Reply With Quote
Old 03-27-2009, 12:01 AM   #20 (permalink)
B_Schutz's Avatar
Bump... I know there was a list in this forum somewhere explaining the peramiters of programers/tuners for 3rd gens, but I cant find it. ???
2004.5 HO325 QC, 4x4, DRW, Goerend, 3.73s, B&D Intake, 5" MBRP, Hot Juice w/att, studs, 90HP DDP, AD150 (IN THE MAIL 64/71/14ss over S480ss)
1994 4x4, 100hp fuel plate, 4000rpm gov springs, 90hp injectors, super B special.
B_Schutz is offline   Reply With Quote
Old 04-01-2009, 12:41 PM   #21 (permalink)
I have a friend that does import tuning. Principles of internal combustion engine do not change though.
The underlying basis of fuel/air/timing/duration/pressure is a very complicated thing and every car/truck is really different. You need to consider many things like use, age, location (sea level or rocky mountain high) HP, torque or Milage. Any and all parameters can be adjusted in theory. Sometimes just changing your oil viscosity/type will make a noticible difference.
What exactly you want as the end result is where you need to concentrate your efforts. There is more to be discussed on this but there are a few constants you can not change.
1. How long it takes YOU, not the other guy running another set up, to get to the 1/4 mile. If that is your goal.
2. How many miles you travel on a tank, IF that is what you are looking for.
Everything else is just a matter of how you want to achieve those goals. The basics are all the same its just how you adapt your surrounding to them.
Key ways to see if changes are worthwile is to keep track of your progress and change only one thing at a time. this way you really know if it made an improvement OR you need to remove it and start again if things got worse.
The cheap easy way to get there is to replicate a successful set up that someone else has already done the research for.
Its oftem more important to ask the questions like how and where do you use your truck, gearing, trans, driving habbits, than what system did you put in there.
Ask carefully you'll get better results.
Otherwise you may spend a lot of $ on figuring out how all these products may NOT work for you.
Think about it. Most imortantly keep track of your changes. What do you think top race teams do. Sometimes they may not even know initially why something works. But you can bet they have kept track of those changes that did work so they can do them again.
MonsterCoatings is offline   Reply With Quote
Old 04-22-2009, 11:25 AM   #22 (permalink)
Tech Specialist
wildcat's Avatar
Were some of you thinking about the matrix done for the 6.7L?
Matrix Update Soon
Bill Mish
2007 Dodge 3500 4X4/5.9L/48RE, KORE, SRT-10 hood, Recon, Isspro, ICEBOX/Amsoil, Walbro, SMARTY, FBD CFM+, FBD HGD, FBD 5" exhaust. FBD TC & VB 458hp/1005tq
ACDC
wildcat is offline   Reply With Quote
Old 04-22-2009, 11:39 AM   #23 (permalink)
crazycatman's Avatar
suscribing for the 3rd gen list
04.5 Qd CB 4X4 AT, Super "B" Special, 'Pusher' int horn, PacBrake, Edge w/Att, S&B Cool air, 4" MBRP, 35 Toyo MT's, air bags, spr hitch, B&W gooseneck hitch, BD Trani parts, guages, lock up switch, smoke switch, horn blstrs
crazycatman is offline   Reply With Quote
Old 06-17-2009, 03:56 AM   #24 (permalink)
Thanks MonsterCoatings for the post. I know you posted a while back but I am new here and the inf. has helped me alot. I got an '05 that I am thinking about stacking a Smarty jr. with a TS Perfomance mp-8. hopefully I do it right.
Joshua Crow
Cav Scout
2005 2500 Big Horn Edition, straight pipe
DieselScout88 is offline   Reply With Quote
