Why loss of antifreeze and serpentine belt? - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-01-2014, 09:05 PM Thread Starter
Pulling off the highway I lost power steering. When I stopped to check I had antifreeze steadily leaking and the serpentine belt was off track. Will a bad water pump cause the belt to jump? What else should I be looking for? Thanks for any feedback.
StansDodge is offline
post #2 of 10 (permalink) Old 03-01-2014, 09:13 PM
EJS0806's Avatar
Check if water pump seized up mine locked up when it went bad and took out the belt as well
12 2500 laramie 4X4 nv5600 S475 fleece coolant bypass 125 injectors steed speed manifold h11s Hamilton 110s 12mm stroker cp3 airdog150 w/sump Southbend 3250 grid heater delete/gdp intake turbo smart bov thuren/carli
EJS0806 is offline
post #3 of 10 (permalink) Old 03-01-2014, 09:15 PM
Tycummins1125's Avatar
Probably due for a new water pump. Just replaced mine cause it started leaking coolant in my garage.
2004.5 2500 4x4 Laramie 5.9 Cummins. 4" turbo back , 5" X series Rough Country suspension lift, FOX SHOCKS 2.0, Smarty S-06 Mag- hytec rear diff cover, with bushwacker flares, XD spy's -12 37x12.50x17 BF Goodrich mud terrain T/A
Tycummins1125 is offline
The Following User Says Thank You to Tycummins1125 For This Useful Post:
StansDodge (03-01-2014)
post #4 of 10 (permalink) Old 03-01-2014, 09:24 PM Thread Starter
Will a faulty water pump cause the belt to jump?
post #5 of 10 (permalink) Old 03-01-2014, 09:47 PM
K9Kodi's Avatar
I assume it depends on how BAD it is. If its bad enough to have enough play in the pulley i can see it wobbling a little, giving the belt ability to jump. Its possible.
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is offline
post #6 of 10 (permalink) Old 03-01-2014, 09:50 PM Thread Starter
Thanks, K9. I assume the loss of the belt is why I lost the power sterring as well.
post #7 of 10 (permalink) Old 03-02-2014, 12:22 AM
The serpentine belt runs a lot! Your alternator, water pump, power steering pump,radiator pulley AC and also has an automatic tensioner, idler pulley and of course the crankshaft pulley. If your belt broke you will NOT have brakes, or like you said power steering etc.. . The truck will run but it is not safe for multiple reason like overheating etc.. My belt broke in my yard 50 yards from the garage. I started the trick and carefully drove it in. Parked it and then bought a new gates HD belt, new water pump and also I found that the idler pulley (small pulley on the top of the belt routing) was bad. Replaced all 3 and been good ever since. Hope this helps. Good luck!
post #8 of 10 (permalink) Old 03-02-2014, 12:25 AM
Oh and a bad WP or idler pulley would prolly cause it jump a groove, but I would replace and keep an eye on it.. if it jumps after replacing parts then you may be due for a new tensioner.
post #9 of 10 (permalink) Old 07-20-2014, 01:39 PM
My serpentine just jumped off for a second time last night - Same issue both times = water pump failure. You can wiggle the water pump probably an inch in any direction. Was a third party replacement, but a somewhat easy fix.
massa_megatron is offline
post #10 of 10 (permalink) Old 07-21-2014, 09:48 AM
stacked cummins's Avatar
I did mine last week. Tired of seeing the little puddles when ever I parked it. If you take out your air box it makes it easier to get to. Took me less then 25 Mins to replace it.
01 rclb ROLLED OVER> KIA
THOR the 98 1 ton cummins build
stacked cummins is offline
