overhead trip computer problems - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-06-2008, 12:14 PM Thread Starter
My overhead computer is not working, all the lights are on, and it will read the direction, ie N S E W, but I cant get any readings for MPG, DTE, etc..what might cause this and where would i start looking..
thanks for any input.
Work truck. 2011 2500 4x4 CCSB, H&S deleted.
Play truck. 1995 2500 4x4 RCLB, 63/475 compounds, 5x0.18, 025DVs, ARPs.
GMCummins is offline
post #2 of 4 (permalink) Old 09-06-2008, 05:01 PM
jhardie's Avatar
My temp takes forever to get a "correct" reading. (It's been near 100* and my reading says 58*) From my understanding, there's a TSB to get the overhead back up to speed.
'06 2500 SLT Mega 4x4, Timbrens, Icebox, Amsoil By-Pass, GDP MK-2 & Big Line, Aero 4040XL, DiPricol Optix Gauges, Bilstein 5100, New front end goodies (ball joints/etc), EBC Sport Rotors/7000 Green Pads---- Sold.
jhardie is offline
post #3 of 4 (permalink) Old 09-06-2008, 05:08 PM
jacksram's Avatar
This is out of the 2001 service manual. It may help you find out whats up.
SELF-DIAGNOSTIC TEST
A self-diagnostic test is used to determine that the
compass mini-trip computer module is operating
properly electrically. Initiate the self-diagnostic test
as follows:
(1) With the ignition switch in the Off position,
simultaneously depress and hold the Step button and
the U.S./Metric button.
(2) Turn the ignition switch to the On position.
(3) Continue to hold both buttons depressed until
the compass mini-trip computer module enters the
display segment test. In this test, all of the Vacuum
Fluorescent Display (VFD) segments are lighted
while the compass mini-trip computer module performs
the following checks:
Microprocessor RAM read/write test
Non-volatile memory read/write test
Microprocessor ROM verification test
CCD communications test.
(4) Following completion of these tests, the compass
mini-trip computer will display one of three
messages: “PASS,” “FAIL,” or “CCd.” Respond to the
respective test results as follows:
If the “PASS” message is displayed, but compass
mini-trip computer operation is still improper, the
use of a DRB scan tool and the proper Diagnostic
Procedures manual are required for further diagnosis.
If the “FAIL” message is displayed, the compass
mini-trip computer module is faulty and must be
replaced.
If the “CCd” message is displayed, the use of a
DRBt scan tool and the proper Diagnostic Procedures
If any VFD segment should fail to light during
the display segment test, the compass mini-trip computer
module is faulty and must be replaced.
(5) If all tests are passed, or if the ignition switch
is turned to the Off position, the compass mini-trip
computer module will automatically return to normal
operation.
2002 Quad short bed, white ,camper special , 4" MBRP 409 turbo back , BHAF ,Edge Ez. Isspro ev EGT , Boost , FP , Rapture 100 w big line
jacksram is offline
post #4 of 4 (permalink) Old 09-06-2008, 09:57 PM Thread Starter
I just tried that self test and it wont work, my truck is an 05, so maybe its different..
