Gauge Install Tips - Dimmer Wire - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 01-04-2013, 03:33 PM Thread Starter
I received a fuel pressure gauge for Xmas and I am installing it soon. After some searching on the internet I stumbled across some good tips from Geno's Garage.
http://www.genosgarage.com/installat...lTips03-09.pdf
Basically at the back of the dimmer switch use the following wires to dim your gauges:
Orange wire with the white stripe for 2003 models only (pin #3 on the headlamp switch).
Orange wire with brown stripe for 2004 and 2005 models (pin #2).
Orange wire with brown stripe for 2006 and 2009 models (pin #4).
For ground, we used a close-by Phillips-head screw and a D-ring attached to the light’s wire.
Originally I opted for a single gauge pod that attached to the stock A-pillar, I have since ordered an SRT-10 single guage pod, I think it looks a lot cleaner.
Bob
'06 MegaCab 3500 CTD, 48RE, AFE 4" Stainless w/ Cat delete, 315/70-17 BFG, Eagle Eye Halo, Edge Juice w/ Attitude, 08.5 Steering, DT track bar, Spicer Ball Joints, Spicer u-joints, Pioneer AVH-X5500BHS, cross-drilled/vented front rotors - more to come...
Sushiholic11 is offline
post #2 of 3 (permalink) Old 01-06-2013, 09:08 AM
krashDH's Avatar
Just did my gauges yesterday. For my 04.5, the dimmer wire is the orange with the brown stripe, on the bottom row. I don't know what pin two was so I just checked the voltage.
2004.5 2500 QCSB 6sp 4x4 SLT. 5" turbo back ,Isspro EV2 gauges, SB DD3250-6, custom intake, Pac exhaust brake w/ on-board air, Pusher intake, leveling kit, Bushwacker Pocket fender flares, custom front and rear bumpers, Smarty S06 POD
krashDH is offline
post #3 of 3 (permalink) Old 01-06-2013, 03:05 PM
Hey Bob,
I have the exact setup on my 4.5 ctd. Super easy instal and if you are only installing one gauge, the SRT is super clean. I would suggest using Posi-Tap connectors. They are the best and will not come undone. My local napa had some. The ability to use the dimmer is nice. My gauge is still a little brighter than the rest of the dash. If I remember correctly, I pulled my keyed hot off the cig lighter (but that may have been another project). Did you get the fuel tee from Geneos also?
04, 2500, CTD, FASS Fuel System, Kore HP, 35", debadged.
bottrigg is offline
