Torque App Android - Transmission Temp - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 07-12-2012, 04:37 PM Thread Starter
KCT
KCT's Avatar
I've been searching the forums (as well as the Torque forum) but haven't found anyone who's been able to get the Tranny temp to register.
Has anyone had any luck getting transmission temperature on the Torque Android app? Any luck with getting the custom PID's? I know our trucks monitor this, it's just a matter of getting it out of the OBDII.
Thanks
2015 Ram 3500 Mega Cab Laramie SRW w/ Aisin
Sold: 2004.5 Quad Cab 4x4 - 48re to g56 swap
, Michelin A/T 315x70x17, Silencer Ring Missing, 3.73, Leveling Kit, Edge w/Attitude (30104), Pacbrake exhaust brake.
KCT is offline
post #2 of 22 (permalink) Old 07-13-2012, 02:17 PM
pjesson's Avatar
It is there because my Edge Juice w/ Attitude reports tranny temp and the only place it gets it is from the OBDII
2007.5 Mega - MP-8, Edge, ISSPro Guages, Gooseneck, airbags, OBA, lighting by KC and Hella front & back
pjesson is offline
post #3 of 22 (permalink) Old 07-13-2012, 06:44 PM Thread Starter
KCT
KCT's Avatar
Update: Was able to get Trans Temp to read. In the custom OBD2 PIDs screen, I added the predefined set "other". This gave me a "Transmission Temperature (Method 3)" option which I added to my gauges screen.
Question - does anyone know if this is accurate? I've plugged in all the info for my truck (via settings). I drove the truck for about 30min on the highway unloaded (outside temp is about 80). Truck sat for about an hour. I started it and idled in park for about 5 min, playing around with the Torque app. Original temp on the torque app after sitting and 5 min idle was 158, when I shut it down it was registering 172 (after about 5min in park).
Question 2: Still can't get rail pressure to read. I plugged in the following to custom PIDs that I found on another thread:
ODB PID = 0123
Long name = Rail Pressure
Short name = Rail
Minimum value = 0
Maximum value = 30
scale factor = x1
Unit type = 1K
Equation = (((A*256)+ B)* 10) / 6894.76
Thanks
KT
KCT is offline
post #4 of 22 (permalink) Old 07-14-2012, 04:36 PM Thread Starter
KCT
KCT's Avatar
Alright figured out that the Trans Temp listed above is really reading coolant temp.
Anyone had luck reading tranny temp and rail pressure?? Anyone??
KCT is offline
post #5 of 22 (permalink) Old 07-18-2012, 07:30 PM Thread Starter
KCT
KCT's Avatar
Bump..... Anyone had luck with Trans Temp and Rail Pressure with Torque?
KCT is offline
post #6 of 22 (permalink) Old 07-19-2012, 04:42 AM
06speed's Avatar
The Torque app has a rail pressure PID already in it. That's the one I use. Although i have entered the custom PID like you have there for rail pressure and it worked as well. I have not gotten the trans temp to read on my cousin's 05 auto. I have a manual.
'06 2500 4x4 QC, G56(MD-50wt)-ValAir Dual Disc, Jacobs ex.brk, crazy larry, Firestone ride-rite bags, Baldwin f/w sep + Cat 2mic filter, EV2-lift,rail,EGT,boost, MBRP 5" w/muff, OEM intake w/Banks Scoop
06speed is offline
post #7 of 22 (permalink) Old 07-19-2012, 11:49 AM
ChucktownJohn's Avatar
Anyone using an old 1st Gen Android? Will it work? My wife has an old one sitting in the drawer. We both have iphones now and the torque app looks better than apps for the iphones.
'04.5 QCSB 4x4 Laramie, XRF, Muff Delete, Suspension Maxx Links
'85 300TD
A couple old Chevy's in pieces...
ChucktownJohn is offline
post #8 of 22 (permalink) Old 07-19-2012, 12:11 PM Thread Starter
KCT
KCT's Avatar
I wonder if the PID's are just different in 2004.5? I can get either to work...
I have a Droid 2
KCT is offline
post #9 of 22 (permalink) Old 07-19-2012, 01:08 PM
Gen-X's Avatar
What bluetooth obd2 are you guys using I'm going to order one since I can't find any locally?
'06 GTX3582r hiding under 2 GT3582r
14 Jeep GC ecodiesel
Gen-X is offline
post #10 of 22 (permalink) Old 07-19-2012, 02:15 PM Thread Starter
KCT
KCT's Avatar
I bought this one (not at this store): ELM327 OBDII Bluetooth Diagnostic Interface Transceiver Adapter For Car Short / Long Term Fuel Trim - ELM327-Diagnostic-Transceiver
Imagestore - ELM327 OBDII Bluetooth Diagnostic Interface Transceiver Adapter For Car Short / Long Term Fuel Trim
I think I got it for less than $20 delivered.
KCT is offline
post #11 of 22 (permalink) Old 07-19-2012, 04:01 PM
Thunder Beast's Avatar
I don't think there is a provision for tranny temp on your year. I have an 05 and there just isn't one. I went with an aftermarket gauge and sender.
2005 3500 Laramie 4x4, Edge Juice with Attitude with "Hot" unlock, Edge Ez, Devils Own H2O injection, FS2500 Oil Bypass Filter, BD aux lift pump, BD Transmission controler, Transmission bulit by J&G Transmission, Bully Dog rfi intake, Banks Monster exaust, MBRP cat delete, DJ motorsports grill, Superlift 6" lift, Toyo 37x13.50x18, 18x10 RBP Wheels,Enkay mud flaps, Weekend on the Edge 2008 Winner in open class!!
Thunder Beast is offline
post #12 of 22 (permalink) Old 07-19-2012, 09:05 PM
hillbilli's Avatar
scanguage has trans temp and rail pressure listed on their site as confirmed for their reader so you have to be able to pull it off someway, just have to find the right commands for torque.
Dodge Specific : Linear Logic : Home of the ScanGauge
2014 Ecodiesel CrewCab
2007 5.9 MEGAcab w/Edge Evolution--Sold
USAF
hillbilli is offline
