I just upgraded my 05 to the new 08.5+ Steering. I did all my research, and I have the newest Mopar part number with the newest pitman arm.
For the first time I have slight bump steer where before I never noticed any bump steer what so ever.
Don't get me wrong the new steering is a huge strength upgrade over the inverted Y, and I don't plan on going back.
I did however at the same time install much softer progressive springs, so maybe the axle is moving more than before and maybe that is causing the noticeable bump steer.
__________________ 05' Quad Cab: Straight Pipe, S&B Intake, Edge Juice, Mixed Parts 3.5" Lift, 37" Extreme MT's, Banks Techni Cooler Saving for: 100hp II Nozzels, Goerand Trans, FASS 165, Amsoil Bypass, BD Super B w/Manifold
Ditto on the slight bumpsteer when initially installed. I got used to it quickly and the tradeoff of the constant toe-in during suspension cycling made it worthwhile.
I have the steering sitting in my garage and will be installing it soon. I have read on here that the new pitman arm is un needed if you have even a leveling lift. If you run it, it can cause interference, and bump steer.
I have done the steering box and the linkage upgrade in the last 50k. I noticed an improvement at first.
I am now thinking that I have to go to an aftermarket track bar and maybe new control arms. I have the clunking when making slow tight turns and long hair pin turns at 25 mph.
I installed the upgraded steering as well and notice more bump steer. I recently replaced my worn out sway bar end links with Maxxlinks and it eliminated by bump steer. I was very surprised it did but hey I'm not complaining.
Know that I think about it, I do remember reading something about having a leveling kit and using the stock pitman arm.
It should be that if the length and angle of the track bar and drag link are equal, then there should be zero bump steer. I'll climb under there and take some measurements.
I am very impressed at how solid the steering feels. New track bar and box brace along with the 08.5+ kit made a big difference.
I was very pleased with the difference but give it some times almost feels the same as the old set up again.
__________________ 2003 Dodge Ram 2500 Silver Laramie 4x4 My Useful Threads: How To: Make HIDS work w/ Resistors, How To: Tint your Tails, Weak Hood Shocks??? HID QUESTIONS YOU ASK....ASK
i have the steering upgrade and had bumpsteer with a leveling kit, and a thuren track bar. i just put new springs (got rid of the leveling kit) sway bar end links, control arms are on the way, and a fox steering stabilizer. no more bumpsteer, i think it is directly related to the stock stabilizer i had a rancho on mine (junk bottom line) after 20000 miles it was so soft and wouldnt even extend.
get a good track bar and stabilizer and you'll be golden
03 qcsb black 4x4 UDC thuren bd r700 48re 85% pump, STAGE 2 BBI's studs springs pushrods fully ported head banks side draft bd manifold intercooler fuel boss 2mic levis blankets
Can someone point point out what steering was replaced under warranty by Dodge? I have a problem checking online about the recalls. And I need new tierod ends, all the joints are junk. I have the stabilizer that bolts through the tierod not the one with the clamp if this helps anyo.e.
06 2500 SB/QC auto 2.5" leveled.
94 2500 LB/SC V10 Plow truck.
3 8.3l cummins in my work trucks.
You have the one that wasnt recalled. You will have to do the update because I do not believe you can get the TRE's anymore.
2006 QC G56 4x4: GT3782R stage 2, BD manifold, Smarty, bunch of other junk.
The Following User Says Thank You to AL06Quad For This Useful Post:
