Hey Fellas......It's Christmas!...Look what I found! - Page 8 - Dodge Cummins Diesel Forum
Old 04-14-2012, 10:10 PM   #85 (permalink)
Im going to check it out tomorrow and if it won't work with my idea or isn't simple enough to modify, I'll call him up. Thanks.
06 2500 SB/QC auto 2.5" leveled.
94 2500 LB/SC V10 Plow truck.
3 8.3l cummins in my work trucks.
E.M.S. is offline   Reply With Quote
Old 04-15-2012, 07:15 AM   #86 (permalink)
Do you know (or Anyone know) if the cab/chassis bracket will fit the Dually trucks?
2004.0 Dodge Ram Quad Cab 2500,Stock 5.9L Diesel H.O. Federal Emissions, 305HP/555lb.ft , 6-speed NV5600 transmission, 2WD with 2" front level, Frantz oil bypass,Vulcan Performance 2 mic under the intake fuel filter kit
Jbremount is offline   Reply With Quote
Old 04-15-2012, 08:01 AM   #87 (permalink)
Dually frames are the same as the srw frames if I remember correctly. I'll check to see if it fits mine but I have a qcsb so that's all I can verify as per tank location and what not other things may be in the way.
Old 04-15-2012, 10:18 AM   #88 (permalink)
MegaB's Avatar
You can always modify the bracket to fit your application . Its just plate steel . Heat , bend , drill , cut , config. to fit .
06 MC 2500 4x4 ; EFI by AD , Banks , aFe , HBS , MBRP , Tuff Country , Thuren , Doghouse 1pc.DL , 6X Isspro EV2 , Custom Billet Badges , Stock 2012 rims , Mopar Severe Duty FF , Retrax PRO . More to come
MegaB is offline   Reply With Quote
Old 04-18-2012, 10:07 PM   #89 (permalink)
purplepuller's Avatar
Originally Posted by Quilbilly Brian View Post
I dont know why you would have to drop the tank. I am attaching a picture of my under the cab install and a list of the fittings I used.
Where did you get the 3/8 to -6an fittings?
2006 2500 Laramie 4x4 QCSB SRW Autometer Pyro, Rail Pressure & Trans Temp, Isspro Oil Pressure 2 inch leveling kit 5100 bilsteins 08.5 steering AFE Stage 2 Pro MBRP 4 inch 285/70/17 Terra Grapplers. Trans rebuilt
purplepuller is offline   Reply With Quote
Old 04-19-2012, 12:57 PM   #90 (permalink)
I'm not sure where the OP got his. I was doing some research and found them at local hose shops, and online at Jegs.com
Tony
1996 VW Passat TDI; Avg 43mpg
2006 VW Jetta TDI; Avg 35mpg
2006 3500 Dually, QC, LB, Laramie, Gauges 16.3mpg, last checked fwy mpg.
TonyB is offline   Reply With Quote
Old 04-19-2012, 01:25 PM   #91 (permalink)
ADawg's Avatar
Try Vulcan Diesel performance
Fittings, Adapters, Fuel Line, Harnesses
2005 dodge cummins 4.5 inch fabtech lift 35 Hankook Dynapro Muds, Home Depot CAI (thanks to AH64ID), SMARTY PoD , banks high ram air intake manifold 4 inch exhaust with a missing muffler and silencer ring: ISSPRO gauges,Frantz oil bypass kitDTT transmission
ADawg is offline   Reply With Quote
Old 04-19-2012, 03:09 PM   #92 (permalink)
heater
How is the heater enabled in a 2004.5.Can it be done?
guesscrazy is offline   Reply With Quote
Old 04-19-2012, 03:16 PM   #93 (permalink)
yes you just need to use the keyed power to your existing heater relay to also pull in the second hearter relay.
1983 2500 Suburban 6.2 sm465 4x4
bftrain is offline   Reply With Quote
Old 04-19-2012, 08:05 PM   #94 (permalink)
Tony
Thanks Got the kit today. Found some online $22 apiece will shop around.
Old 04-20-2012, 11:59 AM   #95 (permalink)
I just got my kit yesterday.
Starting to put together a parts list:
2) Adapter, -6JIC x 12mm
4) 3/8 pushlock x -6 FJIC, 90 degree
2) 3/8 Tube Compression x 3/8 F-NPT (Local hardware store)
2) 3/8 M-NPT x -6 JIC
4') Fuel hose - 4' is a conservative estimate
Anything I'm missing?
I'm also planning to tie the heater relay into the factory heater, as previously mentioned.
The kit mentions replacing the fuel pump module. Anyone have any background on this? Everything I've read indicates this isn't necessary. I figure I've got 57k miles so the factory pump should be sufficient. I also have a fuel pressure gauge and read 9-10 psi at idle, and ~5psi at WOT.
Thanks!
Tony
Old 04-20-2012, 12:08 PM   #96 (permalink)
I would recommend a j30r9 rated fuel hose as it will hold up to biodiesel as well. It should be available at the parts house it has started to replace the j30r7 fuel injection hose which can degrade over time with bio running through it.
Your lift pump should be fine.
The Following User Says Thank You to bftrain For This Useful Post:
dieselenthusiast (04-20-2012)
