Only 1 tire spins??? - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 01-29-2008, 08:25 PM Thread Starter
slvrbullet01's Avatar
When i was in the snow in 2 wheel drive only one tire would spin, but on pavment it seems like i can get both tires to spin. what can i do to get both tires to spin, because eventually when i drag race my truck im gonna want max traction, what would help???
2007 5.9L laramie [/B] AFE intake, ATS manifold, Smarty REVO. guages, AirdogII. leveled/Bilstein 5100's.1992 1st gen P-pumped, Stage 3 Colt Cam, FASS ARP studs, Fluidambr, fire ringed, custom built P-pump, DDP injectors, soon to be twins, 47rh conversion.
slvrbullet01 is offline
post #2 of 8 (permalink) Old 01-30-2008, 12:08 AM
you'll need a locker, posi-trac, limited slip...something along those lines...but I think I saw a thread on here that said that there arent any available for that rear axle...or at least that ARB was not making theirs for it, which would be the way to go for street driving. you dont want to have a full detroit thats engaged all the time for a truck thats driven every day on the street, puts a lot of stress on everything else. search "locker" and see what you come up with.
`06 Ram 2500 SLT QC Auto 4x4, True Flow Intake, silencer ring/baffles removed, muffler/cat removed, Fogzilla w/ Silverstars x 4, Amsoil 15W40, CFM+ w/ ports, Winspeed Heater Delete on the way
rockfrawg is offline
post #3 of 8 (permalink) Old 01-31-2008, 04:36 PM
diesel_dan's Avatar
I can hardly ever get mine to spin both tires if I try. You might want to check your truck for an open diff. by running the VIN # or pull the diff cover. The only option as of now is the factory limited slip. From what I have seen as long as both tires are on the same style of surface they will both spin with the factory limited slip. I will be putting one in my truck within the next couple of months. I'm tired of waiting for an aftermarket solution. It's been over 4 years now that they keep saying it will happen this year, then it doesn't happen.
'06 Dodge Ram 2500 MC 4x4 auto, Trans by Timinva, Flex Plate, HTT 62/65/14, ARP's, O-Ringed, f1 springs and cam, Bladerunner, Fass 150, 5" to 6" stacks, SMARTY POD TNT/R, TST, 7 Optix gauges.1/4mile 12.8400 @ 103.74mph 9-19-08 OUT OF AIR!
diesel_dan is offline
post #4 of 8 (permalink) Old 01-31-2008, 05:00 PM
Banned
IF YOU plan on drag racing the truck, get yourself a spool or weld them spider gears
ccoop769 is offline
post #5 of 8 (permalink) Old 01-31-2008, 05:23 PM
RamThisCummins's Avatar
I know the jeep is the same way- I don't know why they call it 2wd it should be called 1wd
If I get a truck I would put a posi or a locker.
2006 Mega Cab cummins, Firepunk Diesel 48re, my momma said I couldn't handle the v8 so I bought a cummins instead
RamThisCummins is offline
post #6 of 8 (permalink) Old 01-31-2008, 05:24 PM Thread Starter
who makes the limited slip gears??
post #7 of 8 (permalink) Old 01-31-2008, 05:57 PM
Banned
thats not good LOL I have a hard time ever getting one to spin its always both back and most of the time both front.
GETERDID is offline
post #8 of 8 (permalink) Old 02-01-2008, 07:55 PM
Exclamation
theres a bunch that make them check this web site out
Randy's Ring & Pinion
search by make/ model or if u know your axle select that one. Then you click on the axle and it will give u a list of stuff to buy... I.e. lockers, limited slips, gear ratios, etc etc.
let me know if this helps, if u need to know more about the website just ask :thumbsup
