Rough idle engine studders upon decel after bad fuel - Dodge Cummins Diesel Forum
Old 12-10-2011, 02:17 PM   #1 (permalink)
Hi Guys
I have a 06 ram 3500 cummins i recently got fuel and within days ended up with the fuel in water light on drained the seperator and got it again so i drained it again the engine started having acceleration problem where it seemed to be starving for fuel, studdering on the decel and rough idle ...figured bad fuel so i got some diesel 911 additive and put it in got a little better so i ran the truck to empty the tank got down to almost empty and finally the fuel filter plugged so i changed the filter it started so i went and filled it with fresh fuel figuring it would straighten out ....nope same problem please help
Firenut79 is offline   Reply With Quote
Old 12-10-2011, 04:25 PM   #2 (permalink)
I had the same problem with mine but I changed the fuel filter an it fixed the problem you might need to check the fuel pressure don't no it you have a programmer to do that or not it should idle around 14000 psi
Sent from my Autoguide iPhone app
welch11x is offline   Reply With Quote
Old 12-10-2011, 04:36 PM   #3 (permalink)
D45
D45's Avatar
iTrader Score: 14 reviews
Please watch the forum headings
This question is pertaining to your 2006 and this was posted in the 03/04 specific forum
Move for you
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
D45 is offline   Reply With Quote
