Fogged up windows? - Dodge Cummins Diesel Forum
Old 12-09-2011, 11:07 AM   #1 (permalink)
Lonestar '06's Avatar
Fogged up windows?
My windows fog up horrible, it didn't bother me until my wife had to drive in the snow and couldn't see. Just had to keep wiping it away. The blower motor squeals a little but it still blows hard, and it gets hot. I used some rain x anti fog wipes and that didn't work drove 30 miles this mornin and they were still fogged up. Any help would be appreciated!! Thanks Craig
'06 2500 to 3500 drw Quad Cab Longbed 4x4 48RE, Autometer Phantom (Pyro, Boost, Trans Temp) Ranch Hand front replacement
2012 3500 DRW Crew Cab 4x4 G56
Lonestar '06 is offline   Reply With Quote
Old 12-09-2011, 11:12 AM   #2 (permalink)
Diesel-Dave's Avatar
Is your A/C working. The truck is set up to run the A/C when you're on defrost to take the humidity out.
As an aside, rolling down the window just a crack usually takes care of it too--but you'll get cold obviously.
'07.5 2500 ST, 2wd, QCSB, G56 6-speed manual, 3.73 gears. DPF, EGR, IAT, CCV, NOx Cat deletes. Smarty Jr FE tune w/ most adv timing. Homemade ram CAI, Upper & lower grille block, tonneau cover, Dual 150W oil pan heaters ~Fuel mileage obsession~
Diesel-Dave is offline   Reply With Quote
Old 12-09-2011, 11:13 AM   #3 (permalink)
Heater core leaking???
07 Mega, Thuren Bounce
96 3500
pwknapp is offline   Reply With Quote
Old 12-09-2011, 12:20 PM   #4 (permalink)
Snofarmer's Avatar
X2,
time to check the coolant level.
SnoTo Cheap for a brag line~
Snofarmer is offline   Reply With Quote
Old 12-09-2011, 12:31 PM   #5 (permalink)
Rescue Tower
Shainer's Avatar
Also need to know what settings you are on. Recirculate will not dehumidify the cabin.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline   Reply With Quote
Old 12-09-2011, 12:42 PM   #6 (permalink)
As stated...... check for a coolant leak- wet carpet and low coolant level & see if the compressor is running when def is on.
Also, just my opinion-- those rain-x wipes are crap. I used to use them and think they make it worse. My windows always got a haze to them when I used that stuff in a different car. Just clean with a very high quality window cleaner. There's some stuff that comes in a white aerosol can that's good. And/or get a clean towel from the house and just wipe them off without any cleaner. I'm convinced the film left behind by cheap window cleaner makes them fog up a lot quicker.
2006 Laramie 2500 QuadCab 5.9L CTD 4x4
"....the Cummins diesel is the best of the big 3, but it comes wrapped in a Dodge truck."
stb616 is offline   Reply With Quote
Old 12-09-2011, 02:16 PM   #7 (permalink)
pjesson's Avatar
Dirty glass definately fogs up much easier. Make sure they are really, really clean and it makes a huge difference. I agree the rainex wipes have not worked for me either.
But that said, even with filthy, smokey windows you should be getting them cleared in 30 miles. And even with the AC not running. I second/third/fourth the suggestion to check for a leak in the heater core...sounds like you might be steaming your windows when you want to be blowing hot dry air on them.
2007.5 Mega - MP-8, Edge, ISSPro Guages, Gooseneck, airbags, OBA, lighting by KC and Hella front & back
pjesson is online now   Reply With Quote
Old 12-09-2011, 02:36 PM   #8 (permalink)
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
depending on year and equipment level of the truck too i've seen a few odd things happen. Does the truck have clearance lights? I've seen clearance lights leak and get moisture in the truck. Once you get moisture in the carpet or under the carpet I've found that the windows fog up much easier and it becomes much more difficult to defog them. Third tail light leaks and rear window seals are two other frequent offenders for this same problem.
2001 QCLB 3500 Dually 4X4, Stock, FOR SALE 8000 OBO
2003 QCLB 2500 640 HP / 1125 ft/lbs SOLD!
Parts for sale Van Aken SmartBox, Stage II Monster Pump, and FASS 95, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. Parting out 08 3500. http://www.cumminsforum.com/forum/07...-part-out.html.
Shibbyutman is offline   Reply With Quote
Old 12-10-2011, 01:54 PM   #9 (permalink)
chip61's Avatar
No chance you blocked the fresh air intake is there?
07 2500 quad cab 5.9,6spd manual, Smarty Jr. 35-12.50 17 Nitto Trail Grapplers, Carli Starter System and track bar. 1991 W250 auto w/2.5" lift. Brandon Cole Armstrong March 7, 1990-May 14, 2011. He will always be with us. "NVR2TAL"
chip61 is offline   Reply With Quote
Old 12-11-2011, 04:29 PM   #10 (permalink)
Now that you say it I can smell antifreeze, but I haven't found any wet carpet or other leaks. I bet I have a small leak and it is steamin the windows. Will look at that. Even cracking the window wouldn't help. Thanks for the help!!!! New heater core here I come.
Old 01-08-2012, 03:00 AM   #11 (permalink)
Nadz's Avatar
Was the heater core the problem?
2006 3500 Dodge Ram Sport, black, 4" lift, 17"Moto Metal Wheels, 35" Fierce Attitude Tires, AFE Cold Air Intake, MBRP Performance Exhaust, Jake Brake,260,000km, Motor Re-Build @ 124,000. Tough Country front Bumper coming soon.Bad pic!
Nadz is offline   Reply With Quote
Old 01-09-2012, 12:56 AM   #12 (permalink)
Monkeyman2500's Avatar
Yea heater cores suck. Just did one on the wife's 79 Bronco. Don't have a clue how much harder these are. Let us know how it goes.
2004.5, QC,4x4, 6spd, HO, Smarty Jr, AEM Brute Force Intake, 07 Stock Alloy Wheels, 35/12.50/17 Nitto Trail Grapplers, Westin Steps and Brushguard, Isspro Gauges
Monkeyman2500 is offline   Reply With Quote
