Finally hooked up the trailer to the 7-pin and viola ... darkness. Only the left turn/brake light works. No tail lights, marker lights, etc (hopefully I don't have an issue when i finally put a brake controller in ... but one issue at a time)
I found a couple blown fuses. Replaced them, no dice. Will a modulate fix the issues I'm having? I've read that it will fix the turn signals and such but what about the tail lights and marker lights?
2005 2500 5.9 HO. Magnaflow 4" exhaust and K&N intake tube with a paper cone element until I can get an AFE or the like (K&N FILTER IS IN THE TRASH!! ) Otherwise bone stock.
Prior to hooking up my trailer, I had read (on this form - towing section, I think) about the issues with trailer lights. They indicated that the Dodge was designed with basically NO additional light capacity other than what was on the truck! Good thinking? Anyhow, I bought a modulite, installed it and have had no light issues. My trailers have quite a few lights and it all works well. I added large backup/cargo/hookup lights to the truck bed and used the modulite to activate a seperate relay for those. Good luck!
2003 Dodge 3500 Quad Cab, 2WD, DRW, 5.9 Cummins, stock(I'm learning as fast as I can!), 6 speed, flatbed.
1995 Ford F800, 5.9 Cummins, 5 sp Spicer, 10' flatbed (gonna replace the 93 F350, but I haven't told the F350 that yet!)
1993 Ford F350, 7.3 IDI PS, built auto, gooseneck puller
Jay - so your modulite operates all of the trailers lights correct? Not just some? Just want to make sure that Im getting the right thing to fix the whole problem. Also what model did you pick up?
Sent from my DROIDX using Tapatalk
If your tail lights work, then the modulite will work for your trailer lights...
2006 4X4 Quad Cab, SRW, shortbed, mineral gray two tone, auto. Homemade BHAF intake, 5" Magnaflow Exhaust, Smarty Jr, 2" level with 285 70 17 E Firestone Destinations... everything else is stock, maybe someday I can pay to play
No tail lights. Just the left turn/brake. Nothing else
Just looked at the install instructions. They do all of the lights on the trailer so that question is answered. However they only show a flat 4 pin in the instructions. What has everyone else done? Just cut the 4 pin off and run the wires into the 7 pin? Seems logical, just curious what other have done to attach one of these to their 7 pin.
Run the wires from the modulite to the corresponding pin on the 7 pin trailer plug and your "good to go"! Basically, truck wiring harness leads into Modulite, out of Modulite to trailer connector. "Boosting the signal" so to speak. Good luck!
