I am looking at getting some Moto Metal 951 rims with either 33" or 35", but need a little help on which ones to get. I am going to get the 18" ones, but they come in -12, +18 or +30. Which rims and tires will work the best to give me about 2" extended out past the fender (adding fender flares) and will not rub on anything. I will be putting either a block leveling kit, Kore Kit or a Cali Kit, but this really depends on money. Any pros or cons from any of these kits? I should add, is there any additional parts when putting on a leveling kits?
go to carrier spring and order there 2.5'' coil spings i can fit 20s with 35's and 13.5'' wide with no rubbing i think the spings are $250 for both
2007 3500 mega dually 5.9 super b special 100hp sticks s&b cai ats intake manifold fass 165 firestone air bags 19.5s EFI LIVE BY PHIL ANARCHY DIESEL..
2012 QCLB AUTO 4X4 3"BDS lift 37s on stock firestone rear airbags s&b CAI, silencer ring MIA,sinister egr deletes,airdogII 165, 5 inch flo pro turbo back straight pipe, batmowheel stock vgt,mini max HS overdrive waitin in mcc..TRADED
My rims have a +18 mm offset and a 5.71" backspacing. They never rub with the 35's and i added flares. The flares cover the tires. I'd say go with the +18 mm offset if you don't want any rubbing issues.
Nope no change to anything else.. they will even work with your stock shocks but i just bought rancho 2'' lifted shocks but you dont have to
nope nothing take out your old coil springs throw the new ones in and you will get ur truck leveled way better then throwing spacers in and they are very heavy duty if you plow truck wont even sag when u lift it up makes a 2500 feel like a 1 ton tho other then that its a nice setup
Agree with Blue, however, the spacers are cheaper. Which is why I went that route. Either way you'll be good fitting 35's under it as long as you have a positive offset value and try to get close to 5.5-6.0" of backspacing.
So if I go with the ones below they will fill up the fender wells pretty nicely, stick out a couple inches to be even with the ATS flares and provide no rubbing with a Mickey Thompson ATZ 305/70/R18?
yea money whys spacers are a better choice both setups will work for what you wanna do now the hard part... decision
