06 track bar bushings - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 08-25-2011, 09:32 PM Thread Starter
tdrive0001's Avatar
i knew i should have listened to this forum... you guys told me that the moog track bar bushings were junk... YOU WERE RIGHT!!! i'm not spending $340 on an adjustable track bar for a stock height, stock tire daily driver. so here's what i'm thinking and need input on... im getting a new set of moog bushings, but only long enough to take them to my machinist buddy to have them made out of hardened steel or billet aluminum. I NEED OPINIONS ON THIS!!! let me know what you think... thanks.
06 5.9 QCSB 4X4, Fuel mods: Big Foot, Air Mods: silencer ring tossed, Exhaust Mods: straight pipe from turbo to bumper. Looking for free HP
tdrive0001 is offline
post #2 of 18 (permalink) Old 08-26-2011, 01:07 AM
Heckuvatrk's Avatar
You might try the Luke Link Tracbar Bushings...it really helped my truck! I've got a 2 inch leveling kit, Bilstein's, Maxx link sway bar links and the 08 upgrade tierod with a dual steering stabilizer and a steering box stabilizer...I got the bushings from Geno's Garage...good luck with your truck!
2K3 Ram 2500, 305/555HO,EDGE Evolution, FASS HPFP, 4" Diamond Eye, 08.5 tierod, BD str Stab, dual rancho stabilizers,Bilsteins, Maxx links, 2" lvl,Suncoast VB/TC/Flexplate and Sonnax Input shaft, pusher intake, ARP625, BD Tow Twins 509hp 1024 tq
Heckuvatrk is offline
post #3 of 18 (permalink) Old 08-26-2011, 01:42 PM
just spend $36 on the lukes link poly bushings for the 3rd gen trac bar and pound out the old ones, slide in the new ones and be done with it. Dont replace a bushing with a solid steel or aluminum one... that defeats the purpose of a bushing. Get your lukes link from genos garage, It took me about 2hrs to install them in my truck. I just left the truck on the ground, removed the trac bar, drilled out the middle of the original bushing (metal center insert) and pounded out the original bushing. I coated the lukes link bushing in grease and installed it... no big deal.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #4 of 18 (permalink) Old 06-24-2012, 08:56 PM
Justeatn's Avatar
The Website doesnt say anything about if it fits a 2500... does this mean that i have the same front end as a 1500?
it even says that it fits to a certain date but nothing about what size truck.
I have the same huge single cluck from lock to lock and loose steering. Everyone keeps saying just the track bar bushings but it doesnt have any play (that I can feel) but neither does anything that I can find. the truck is about to hit 130k what else should I be looking to replace/upgrade.
2006 Ram SL 2500HD 4X4, 5.9L Cummins, Smarty Jr. (Econ Setting), K&N 4in Torque Tube, Silencer Ring... MIA, 4in TBE to 5in Tip, 3in Levelers, 315.70R17 Custom built Pipe Bumper Recon Headlights
Justeatn is offline
post #5 of 18 (permalink) Old 06-24-2012, 09:12 PM
gunslinger226's Avatar
Genos garage sells Lukes links
2013 2500 Mega Cab Laramie Bright white,EFI live tuned by Hardway Perfromance.
2004.5 2500 62/s475 built trans and lots fuel: Sold
gunslinger226 is offline
post #6 of 18 (permalink) Old 06-24-2012, 09:48 PM
Justeatn's Avatar
Replacement track bar bushings for '03-'07 Dodge Ram.-Geno's Garage
this is the link to them but it doesnt say if it fits both the 1500 or the 2500/3500. But I dont know if its the exact same set up as a 1/2 ton ram...
Justeatn is offline
post #7 of 18 (permalink) Old 06-26-2012, 11:38 AM
rgsauger's Avatar
Dude, just buy the LL bushing kit. Solid mounts will ride like CHEET!!!
Track Bar Rebuild w/ Lukes Links Write Up
06 Mega 4WD,Transgo, 315K miles, 2" TopGunz kit,4.11, H-2 wheels,35/12.50/17E BFG's, Flashpaq, K&N, B&W goose, dual shocks at each corner up front, steering box brace, and a bigass dent in the tailgate because my wife just had to back the trailer...
rgsauger is offline
post #8 of 18 (permalink) Old 06-26-2012, 11:58 AM Thread Starter
tdrive0001's Avatar
Bought a new factory trackbar from the dealer for less than $300. Put it on, no problems since. Been on about 6 months now...
post #9 of 18 (permalink) Old 06-26-2012, 12:10 PM
So i take it these wont work on my 07 with a 6.7 as its an 07.5? Is there any replacement bushings out here for my year truck?
Deleted 07.5 3500 QCLB
LangleyCummins is offline
post #10 of 18 (permalink) Old 06-26-2012, 04:32 PM
crashfirepm53's Avatar
[QUOTE=MPD106;4369212]just spend $36 on the lukes link poly bushings for the 3rd gen trac bar and pound out the old ones, slide in the new ones and be done with it. Dont replace a bushing with a solid steel or aluminum one... that defeats the purpose of a bushing. Get your lukes link from genos garage, It took me about 2hrs to install them in my truck. I just left the truck on the ground, removed the trac bar, drilled out the middle of the original bushing (metal center insert) and pounded out the original bushing. I coated the lukes link bushing in grease and installed it... no big deal.[/QUOTE
I switched to the poly bushings 3 years ago that Luke sells. About $30.00 and she hasn't made any noises again.
2007 MEGA 5.9,4x4,no silencer ring,AFE stage 2 CAI 5" FB Exst,Tuff Country 6'' lift, Atturo MT 37x13.50-20 MOTO METAL 970's Flashpaq,N-FAB LineX 3 step bars,Amsoil Bypass, Eclipse in dash Navigation/DVD, Kicker 400 Mono,12" MB Quart, DDMtuning Raptor HID
crashfirepm53 is offline
The Following User Says Thank You to crashfirepm53 For This Useful Post:
Justeatn (06-26-2012)
post #11 of 18 (permalink) Old 06-26-2012, 07:10 PM
rgsauger's Avatar
[quote=crashfirepm53;5260733]
Originally Posted by MPD106 View Post
just spend $36 on the lukes link poly bushings for the 3rd gen trac bar and pound out the old ones, slide in the new ones and be done with it. .[/QUOTE
What he said...
rgsauger is offline
The Following User Says Thank You to rgsauger For This Useful Post:
post #12 of 18 (permalink) Old 06-26-2012, 08:23 PM
Justeatn's Avatar
Well for just a temp thing I TQ'd them down to specs and it was only about a round and a half but big threads so it pulled good and tight.
Now I cant make it Clunk! Everyday backing out of the drive and nothing. I even tried to pull into a parking lot with a bump up from the road and nothing... so if or when it starts back up ill take down mine and get the Thuren replacement. I have the 2' levelers and that is whats jacking with it I bet.
Just wondering but did you ever try to tighten before you replaced? just asking not trying to be an a$$. just making sure im not just prolonging the inevitable.
Again thanks for the reply guys.
Justeatn is offline
