Need Help! Trailer Wiring - Dodge Cummins Diesel Forum
Old 08-21-2011, 06:31 PM   #1 (permalink)
SixSpeed5's Avatar
Hey Guys, Just bought a new 03 3500 QC. Someone...or whatever reason cut the factory 7-Way connector off and "wired up" a 5-Way. And by "wired up" I mean ruined. They cut the wiring harness off at, where I would assume, normally there would have been some sort of connector.
I have spent two hours now searching various forums, and staring at the Dodge "Wiring Diagram". And by "Wiring Diagram" I mean pile of garbage. I have had dozens of cars from various manufacturers over the years, and this is easily the worst wiring diagram I have run across...maybe I am missing something.
The "Spit" in the harness has twelve wires total, two going into a small "harness" which goes into the tailgate lights. I am left with ten cut wires, with unknown purposes.
Is there anyone who can help me out with this? I would be incredibly grateful. I really would like to figure out the function of these wires, I need to put the 7-Way back in the truck. Normally I would just start with the multimeter, but since there are 10 wires, not 7, I don't want to get anything mixed up.
Thanks!
2003 Ram 3500 DRW - QC 4x4 - HO Handshaker
SixSpeed5 is offline   Reply With Quote
Old 08-21-2011, 06:39 PM   #2 (permalink)
redraider2011's Avatar
Get out a volt meter and start using various functions of the truck lol
-2004.5 2500 QCSB sport, smarty POD TNT, airdog150, goerend, Bosch MS 100's. Focals, JL audio and AudioTechnix audio
TTU alumni!!!
redraider2011 is offline   Reply With Quote
Old 08-21-2011, 06:39 PM   #3 (permalink)
rhorer's Avatar
I suggest looking into a replacement wiring harness. Weigh the $100 or so (last time I priced them at the dealership for my '03 1500) with the value of your time to figure it all out and the headache you'll have when one or more of the 10 (!) spices goes bad. It's all plug and play (at least for the 1500) so you don't have to worry about which wires do what.
2008 QCSB 2500 2WD auto, deleted with Smarty and Juice CTS but otherwise stock
rhorer is offline   Reply With Quote
Old 08-21-2011, 06:44 PM   #4 (permalink)
Motorboat's Avatar
Just an observation but I swear they look like speaker wires to me. All you really can do at this point is to use a ciruit tester and firgure oure out what wire does what. Example: left turn signal blinking, find a wire at the rear that activates intermitantly. Then you can buy a seven way socket and wire it right. Brown=running, green=right turn,yellow=left turn, white=ground, etc.. Better double check me as I've a had a few toddys but you get the idea.
'97 3500. 4X4 3:55s, built auto, vb and triple disc tc w/lockup. Boost, trans, pyro and F/P. Silicone hoses and boots. Icebox intake, 4" Diamondeye. 10 plate, 330s, 60# springs, 4GSK, Pacbrake. Mag trans and diff covers. Firestone Bags and 51 Gal. transfer tank.
Motorboat is offline   Reply With Quote
Old 08-21-2011, 07:56 PM   #5 (permalink)
rhagfo's Avatar
I think if mine was that messed up I would just buy the new harness. I would see a lot less grief in your future!
It never amazes me what people will do to wiring! For the Original owner it would have been far easier, and cleaner to build a 7 pin to 5 pin adapter.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 258K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 16 PSI, 3.55's, Kool Vue Tow mirrors, Pacbrake, Puke bottle deleted.
rhagfo is offline   Reply With Quote
Old 08-21-2011, 08:06 PM   #6 (permalink)
06 stock
02 stock
97 stock
truckndiesl is offline   Reply With Quote
Old 08-21-2011, 08:10 PM   #7 (permalink)
CTD&TDI's Avatar
none of those colors really match up on the dodge harness...your best bet is to either replace the harness like suggested (if thats possible, im thinking its in the main trunk harness that controls everything) or to use the dodge factory wiring diagram to tell you whats what. And even that is a PITA.....
If you need it, PM me and I can send you the pdf of the wiring
2007 3500 C&C, 6.7 CTD, Aisin, 4.10, 4x4, Black, Reg cab, 157k, 23ME, Flo-Pro 5" TBE, EV2-Boost, Tranny Temp, FP, EGT, DP,CW6.7 Pod, Airdog FP100, GDP Canister Delete, S&B CAI, GDP Arctic Air...
2004 3500, 5.9 CTD, 6 spd, 3.73, 4x2, Black, Quad cab, 168k, DiPricol Optix FP, EGT, Boost, AFE Bladerunner IC, Cowl Hood, Airdog FP100, GDP Canister Delete
1995 3500, 5.9 CTD, 5 spd, 4x2, Black, Reg Cab, Laramie, 106k, 4" TBE from RSD, Isspro EV's 60 FP, 60 Boost, Pyro going in next...
CTD&TDI is offline   Reply With Quote
Old 08-21-2011, 08:11 PM   #8 (permalink)
06 stock
02 stock
97 stock
