Has anyone had a problem with their truck squeaking a lot? I washed the truck and but in a Juice box and now anytime under torque it squeaks horribly. I sprayed what I thought was most to all of the bushings with PB Blaster but it still squeaks? Any suggestions???
Thanks,
Jim
2003 Dodge Ram 3500 QC built auto guages air dog updated motor and bully dog; 1989 350 4x4 dump;1995 ram 2500 12v...WIP;
I have a 04.5 3500 dually, and have horribble suspension 'squeaks'. I have had it into the dealer for repair, and they are dumbfounded! They were considering replacing all bushings on rear, and shocks on front, but service manager has been fired, and now we are starting all over again. Not sure if it will get resolved as i have traded this truck for an 06.
2008 MegaCab 3500 Laramie Auto, Not STOCK Anymore.......
When it comes to squeaks, dealers will make up all sorts of funky stuff that sounds good and cost a lot of money. Now...if your under warranty, you might be better off, however you may still have to bring it in more then once. In their defense however, squeaks are difficult to diagnose, I would suggest either run a 7" straight pipe, or crank up the tunes. But keep on checking those bushings, you might get lucky and find the right one. Maybe start with your leaf spring bushings, as you said you notice it the most when w/ a load.
I have an annoying squeek too. I sprayed all the bushings with a rubber lube to see if it was even from anything like that. It helped, but didn't get it to quite. I have been all over on this truck trying. The only thing that looks suspicious is the upper control arm on the passenger side. The bushing there has twisted and it looks like there is some metal to metal action going on. Can't get my big head in there far enough to tell though...
2004.5 Cummins HO QCSB 4X4 SLT, TST PMCR, BDDL, HTB2 62/14, DDP 90's, Goerend Full Billet Trans/TC/VB, FASS 95, Amsoil 4090 on K&N, Magnaflow SS, Smittybuilt Bars, Westin Grille Guard, Di-Pricol Optix Gauges, Tuff Country 4.5" Lift, Eagle rims, 35/12.5/18 Toyo MT's, Bushwacker Flares
2001 Cummins SO QCSB 4x4 Laramie, Edge Juice w/Att, Airdog, Amsoil 4095, 4" Magnaflow SS - Looking for a 2nd Gen 6spd
It is annoying but does not seem to be a concern. I think if I keep spraying bushings and get some miles on the truck it will hopefully go away. I checked Universals first thing, tight as could be. Its going to be something stupid just gotta find it.
