bought my truck used, are THESE parts STOCK?? *PICS* - Dodge Cummins Diesel Forum
Old 08-14-2011, 10:44 PM   #1 (permalink)
I'm wondering if these control arms are stock?
Is this a problem?
07liftedmega is offline   Reply With Quote
Old 08-14-2011, 11:11 PM   #2 (permalink)
lilryan's Avatar
they are not stock. and what are you asking about as far as the problem goes.
06 2500 mega cab / floorit 48re & diy / mag covers / FTE exhaust / DPS 2nd gen mani / 62/65/14 / bmk-21 / tc prv / SSR / FASS 150 / vulcan liberty canister / arp 625 / ported & o-ringed head / custom side draft intake manifold / thuren trackbar 495hp 1103tq
lilryan is offline   Reply With Quote
Old 08-14-2011, 11:14 PM   #3 (permalink)
DmaxEter's Avatar
No, those are not stock. Those are Superlift control arms.
Yes, that is a slight problem. Our Jeeps sway bar links tend to do that but my solution was to just get rid of the sway bar. I dont recomend this on your truck.
2006 Quad Cab LWB 2500 Auto 2WD.
DmaxEter is offline   Reply With Quote
Old 08-14-2011, 11:22 PM   #4 (permalink)
Thanks, I'm new to diesels,4wd and solid front axles. The sway bar does come in contact with the coils when I hit a bump, I'm just trying to figure out if I can run 37s on this truck, I'm pretty sure it has a 6" lift, but the steering looks stock
Old 08-14-2011, 11:27 PM   #5 (permalink)
dom42's Avatar
Yeah those are superlift and they moved your axle forward therefore causing the contact on sway bar end.
1. you can make a custom bracket to move the sway bar forward a little.
2. get a custom made sway bar where the distance from the 90* bend is shorter then what it is now. I got a carli sway bar and made it shorter by an inch .
3. or remove it completely.
good luck
Original Designs, LLC
dom42 is offline   Reply With Quote
Old 08-14-2011, 11:30 PM   #6 (permalink)
What do most people do? I know that on the toyotas they would just take them off
Here's a front pic
Old 08-15-2011, 06:24 PM   #7 (permalink)
I dont know if removing the sway bar is a good Idea on these trucks. I did it on my lifted 95 1/2 ton but these things are way heavier. It looks like the contact is minimal. I wonder if you could slot the holes on the sway bar frame bracket to move it forward just a hair. Looks like you wont need more than 1/4 inch
06 Megacab Laramie
03 Mustang SVT Cobra Convertible (sadly sold)
king nothing is online now   Reply With Quote
Old 08-15-2011, 07:47 PM   #8 (permalink)
lmeyer9916's Avatar
iTrader Score: 4 reviews
Running with no swaybar.
03 2500, 6 spd, 4x4, leveled, 315-70R-17's, BHAF, A-1 studs, Hamilton 181/210, SMARTY, Amsoil bypass,ATS exh man., Fluidampr, Airdog, 09 steering, KC's on top, DDP 50HP Inj's, Garrett Stg 2, Jake Brake, OASIS XD4000, 10 gals of tanks, shocker XL's
lmeyer9916 is offline   Reply With Quote
Old 08-15-2011, 08:08 PM   #9 (permalink)
lilryan's Avatar
i have taken mine off, but i dont have a lift. i like the way the truck feels myself. i have read that people dont encourage it when you are lifted. if you do a search, there are plenty of threads on it.
Old 08-15-2011, 10:22 PM   #10 (permalink)
macko300exc's Avatar
Mines off due to the fact my endlinks were bad and i took it off as i didn't have time to change them. 2 years later the sway bar is still in the shop corner
OHIO COAL ROLLERS
macko300exc is offline   Reply With Quote
Old 08-16-2011, 03:01 AM   #11 (permalink)
dom42's Avatar
I know a few guys running no sway bar. But they are not lifted hi and have some bad arse shock to help the sway out. I had it off only because i had the same situation as you when i installed the long arms. But , like i said. i fix it w/ a carli sway bar (that i had to modify) . Im sure if you told carli to make it for u . they would . same w/ thuren. but im 1st in line with thuren. just saying lol
Old 08-16-2011, 08:26 AM   #12 (permalink)
tinman23's Avatar
You could spin the coil spring around so that the sway bar doesn't constantly touch the coil. My 05's sway bar contacted the coil when I lifted it 6", and spinning the coil kept the bar end off the coil. The contact was very little and seldom, so I just kept an eye on it--never seemed to wear.
06 Mega 2500 4x4 | Garmon 48RE | Smarty S06 | Flo~Pro 5" TBE | FTE 30" resonator | BDS 8" Long Arm | Toyo M/T 37x13.50 | Fuel Hostage 20x10 | ISSPRO EV2 x6
Custom Diesel steering box brace | WeatherTech DigiFit FloorLiners | Vent Visors | Connex 3300HP | Wilson 5000 roof mount
Too Much
tinman23 is offline   Reply With Quote
