wheel bearing ? - Dodge Cummins Diesel Forum
Old 08-04-2011, 06:53 PM   #1 (permalink)
camperhead's Avatar
wheel bearing ?
Seems to me i read somewhere that you could buy the correct bearing to put in the flanges at a regular bearing supply house if you knew the correct part number... Alot cheaper Also!!!!!!!!!!!! anybody remember that??
05 2500 Ext cab, short bed, 4x4, Auto, 5" TBE from Farmboys with muffler & resonator from FTE, Smarty POD with REVO , K&N air w/tube, leveling kit,Autometer pyro, boost and trans temp guage,
camperhead is offline   Reply With Quote
Old 08-04-2011, 07:04 PM   #2 (permalink)
Bangin' through the gears
Sandaholic's Avatar
Nope. I thought the unitized bearings were basically garbage when they quit. Interested to see the writeup on this.
05' QCLB 4x4 NV5600,Spec DD clutch,SuperBSpecial,ATS Mani,Flux 3's,Stock CP3,Isspro Performax,S-06,AIS WMI,Airdog 150 Draw Straw V,AiraidCAI,Banks techni-cooler,Mag Hytec rear diff. cover,Protech headache rack and in bed toolbox, Anti-Wrap Traction Chain Device
,6" Atlas leafs & Custom LT Airbags, 16gal. of 200 PSI OBA <<<Link to pics
647/1180 12.861@107.39 7700lb race weight
Sandaholic is offline   Reply With Quote
Old 08-04-2011, 07:20 PM   #3 (permalink)
Yeah, I do remember a post on here where someone mentioned doing that.
Came across it here searching for help about the time I did my bearings.
Sorry, but I don't remember much else about it.
04.5 3500 QC/LB SRW, 4x4, Auto, Stock, Timken Hubs, XRF Ball Joints, Spicer U-joints, EBC Rotors, and GreenStuff Pads, One Piece Aluminum Driveshaft, Cooper AT/3 285/70/17, Mag-Hytec Covers, ISSPRO's EV2, MAXX Links, Bilsteins .... DODGE QUALITY SUCKS !!
DennisNYS is offline   Reply With Quote
Old 08-09-2011, 10:23 AM   #4 (permalink)
rgsauger's Avatar
Technically, you can do what you are talking about to basically any "unit" bearing. You press the two halves apart and then start pressing out the old bearings and then pressing in the new ones. It is very doable, but would be a tremendous PITA. You will need either a larger arbor press and a buddy or at minimum a hydraulic H-style press and a series of adaptors.
You can buy new assemblies for around $250, a little less of you really dig. you will spend $75 or so on the aftermarket Timkens to out in the hub. So, you're really only going to save $150 or so and it is a MOFO job.
With so much riding on this (literally), I would tend to recommend that you replace the bad one with a "real" new on and then experiement on the one you pull out. Maybe rebuild it and see what it takes. If you are pleased, then run it on the other side when it goes out. It's a helluva thing to commit to if it doesn't come out quite right and you have your rig torn down.
Good luck. If you do it, take plenty of pics.
06 Megacab 4WD,Transgo kit, 2" TopGunz kit,4.11, H-2 wheels,315/70/17 BFG's, Flashpaq, K&N, B&W goose, dual shocks at each corner up front, steering box brace, and a bigass dent in the tailgate because my wife just had to back the trailer...
rgsauger is offline   Reply With Quote
Old 08-10-2011, 12:19 AM   #5 (permalink)
Sandaholic's Avatar
Good idea.
