YET another issue with my cummins - Dodge Cummins Diesel Forum
Old 06-29-2011, 10:11 AM   #1 (permalink)
Nothin but a Cummins's Avatar
Ok guys so Im getting pretty sick of this truck. I have a bad vibration in my truck from 80-100kms. Ive replaced tie rod ends, ball joints, ujoints. Ive replaced the 2 piece driveshaft with a one piece and nothing has stopped this vib. Thats just one issue. In the last 2 days my truck has been making a fairly loud "gurgling" sound from what I can tell its coming from the passenger side. Ive tried to lift the hood and pinpoint it under the hood but the noise from the motor is to loud to find where its coming from. Its super annoying inside the cab. Ive never heard this sound before and now it seems that its getting worse and worse everyday. Does anyone have any ideas what this could be??
2006 Mega Cab 5.9L/ bd 48re/ efi live/ Pure Performance/carli/ bilstein/ thuren/ k&n/ mbrp/ bullydog/37x13.50x20 toyo mt/ train horns
Nothin but a Cummins is offline   Reply With Quote
Old 06-29-2011, 12:17 PM   #2 (permalink)
Innovative Diesel
DODGE74's Avatar
iTrader Score: 15 reviews
Have you had the wheels and tires balanced lately?
Are you running the AC or anything when you hear the gurgling?
Cummins EFILive and Smarty UDC custom tuning specialists
Check out our build thread! http://www.cumminsforum.com/forum/in...hop-truck.html
https://www.facebook.com/innovativediesel?fref=ts
www.innovativediesel.com
gordon@innovativediesel.com
866-642-7844
DODGE74 is offline   Reply With Quote
Old 06-29-2011, 12:21 PM   #3 (permalink)
Ive had my wheels and tires balanced within 100 kms. And the gurgling is there whether the ac is on or off. And my ac hasnt worked all year. I didnt know if that would make that sound. I think Im out of freon. But still not sure that being out of freon would make that sound. Its getting louder and louder all the time.
Old 06-29-2011, 01:15 PM   #4 (permalink)
Is it running hot? Is your coolent level ok? Is your passenger hungry? sorry had to do it.
03 SO nv4500 4X4 ,AFE CA, 5" MPRB,ISSPRO, 35" NITTO terras, H2 rims, AirDog150, Pure Performance 3.5" lift
Diesel Dave is offline   Reply With Quote
Old 06-29-2011, 01:57 PM   #5 (permalink)
Doesnt seem to running any hotter then normal. Adn no my passenger wasnt hungry lol!! Coolant level is ok also??????
Old 06-29-2011, 09:29 PM   #6 (permalink)
Is the vibration you're feeling noticeable in the steering wheel or do you feel it more in the truck itself.
While your tires might be balanced there's a possibility you have one (or more) tires with a cord or two let go inside which causes a deformaty. Very easy way to test this, just need to get the wheel off the ground. Grab a hammer, piece of wood, anything of the sort around 12" long. Stand it up beside the tire in the middle of the tread about 1/2" away. Spin the tire slowly and watch that 1/2" gap between your tool and the tire. If it changes at all you have a deformed tire. If it's deformed bad enough it will cause some wicked vibrations.
Had all 4 tires do that on my Jetta and it was the exact same symptoms. You seem to have gone through every other possibility so this might be your fix.
2005 Dodge Ram 2500 4x4, 5.9 Auto, 2.5" Rough Country level, 315/70/17 Cooper Discover ATR's, 8'2" Boss V-Blade, DTT Billet Trans, Goerend Billet Triple Disc Converter, Autometer Gauges, Silverline 4" TB
Geezir is offline   Reply With Quote
The Following User Says Thank You to Geezir For This Useful Post:
ehopp88ss (07-07-2011)
Old 06-29-2011, 09:54 PM   #7 (permalink)
ShayetonKnake's Avatar
Mine was making that noise to not the vibration mine was low coolant level but ive heard it can be caused from clogged heater core?
1999 Dodge ram 2500 Quad Cab 4X4 Auto[/B], Holset HE451VE Billet Wheel W/Fleece VGT controller, Lightning VP44,70HP Sticks,Edge JuiceWAttitude Level6UNL,Banghart Special Auto Trans with tripple disc converter billet input, Billet Flexplate,deep trans pan, Airdog 150GPH, K&N Intake,ATS T4 Exhaust Man,S&B Intake elbow, biggest cam without fly cutting pistons, Upgraded pushtubes and springs,Head ported all the way, 4inch Straight MBRP Duals, ARP 625 Head studs,fire ringed,12 valve rods, girdle kit,14mm main stud kit 17inch 3rd Gen rims with Mikey Thompson ATZ 315/70R17 [SIGPIC][/SIGPIC]
ShayetonKnake is offline   Reply With Quote
Old 06-30-2011, 09:19 AM   #8 (permalink)
The vib is in the wheel sometimes not all the time so I figured if it were my wheels then it would be in the steering wheel all the time. I noticed yesterday while I had the truck running, the farther away from the truck the easier it is to hear the sound. The closer you are the more the motor drowns the sound out. But in the cab its VERY noticable. If it were the heater core would it make the sound regardless if the heater was on or not? I cant seem to pinpont the sound. Its very hard to follow with the truck running.
Old 06-30-2011, 09:30 AM   #9 (permalink)
D45
D45's Avatar
iTrader Score: 14 reviews
Front driveshaft.....
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
D45 is offline   Reply With Quote
The Following User Says Thank You to D45 For This Useful Post:
ffdino (07-24-2011)
Old 06-30-2011, 09:34 AM   #10 (permalink)
haha I took the front shaft out on monday hoping that was the issue. And......nope not the problem.
Old 07-02-2011, 08:29 PM   #11 (permalink)
Gurgling Sound??
[QUOTE= In the last 2 days my truck has been making a fairly loud "gurgling" sound from what I can tell its coming from the passenger side. Ive tried to lift the hood and pinpoint it under the hood but the noise from the motor is to loud to find where its coming from. Its super annoying inside the cab. Ive never heard this sound before and now it seems that its getting worse and worse everyday. Does anyone have any ideas what this could be??[/QUOTE]
I have the "gurgling" sound too coming from the passenger side. I looked under the hood and couldn't pinpoint it. AC/heater was off, coolant level fine, so I can't figure it out.
Anyone know what the problem is??
2006 Megacab 4x4
JT824Megacab is offline   Reply With Quote
Old 07-02-2011, 08:37 PM   #12 (permalink)
03/5.9/CTD's Avatar
Isn't the heater core behind the passenger airbag? I think it would make the noise whether on or off? Correct me if I'm wrong
2012 3500 4x4 GMC Denali QCLB DRW. Duramax. Stock.
2005 2500 4x4 QCSB G56. Not Stock.
1991 W350 4x4 SCFB G360. Not Stock.
03/5.9/CTD is offline   Reply With Quote
