3 inch lift fit 37 inch Tires??? need help - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 06-16-2011, 09:49 PM Thread Starter
Hi i am wanting to put toyo open country mt 37 13.5 17 under my 3 inch pro comp lift will this be duable ? i have xd series spy wheels going with it i am thinking the back spacing is stock. i want to have the tires for the wider look hard to find a 13.5 tire please give info if they will not fit i am going to try trxus sts 35 12.5 17 i heard they last long anyone have pics of this kind of set up will greatly appreciate it and any info that can help out thanks
kameronkdr1 is offline
post #2 of 22 (permalink) Old 06-17-2011, 01:33 AM
xXxSilveradoxXx's Avatar
Check this thread out.
Thuren Long Arms, King 3.0s/2.5s, 37"s, 4.10s, Smarty S06, Garrett GT3788R with 0.89 A/R, Garmon SR96, Cool Hose/AMS/Whistler, Banks 4" Turbo-Back Exhaust, PacBrake
xXxSilveradoxXx is offline
post #3 of 22 (permalink) Old 06-17-2011, 01:41 AM
Laz04's Avatar
What I've found when mounting 35"inch+ tires on 3rd generation Rams or newer is that the stock wheels(or same back spacing wheels) work best as well as no wider then 12.5"inch tires. You may get lucky and fit these 37x13.5's but they might rub on the lower air valance and/or the upper control arm at full lock. Let Us Know how the install goes and post pictures with them on there.
I'm always a fan of the mildly lifted trucks with the biggest tires you can stuff in the wheel well. It closes up the gap nicely and makes a truck look really aggressive in my option.
2006 3500 6x6 Crew Cab Cummins-Smarty,EDGE Juice with Attitude, Quad Boost-Fooler, S&B Intake, 5" TBE 5" Fabtech Lift.
Laz04 is offline
post #4 of 22 (permalink) Old 06-17-2011, 01:50 AM
My 04.5 Ram
37s with a completely stock suspension.
post #5 of 22 (permalink) Old 06-19-2011, 08:50 PM
03 Rammer's Avatar
Check out the thread "Stock w/ Big Meat" Lots of trucks running 37s with stock wheels and no lift
2003 Dodge Ram 2500 Silver Laramie 4x4 My Useful Threads: How To: Make HIDS work w/ Resistors, How To: Tint your Tails, Weak Hood Shocks???
HID QUESTIONS YOU ASK....ASK
03 Rammer is offline
post #6 of 22 (permalink) Old 06-20-2011, 03:58 PM
cummins2855's Avatar
you can definetly clear the 37's
cummins2855 is offline
post #7 of 22 (permalink) Old 06-20-2011, 05:48 PM
not all tires are created equal, and for the most part, BFG's dont measure what they say on the side wall. i know this from past trucks, and running BFG's, maybe they are closer to the specs on the side wall these days i am not sure, but my toyo MT's were bigger then my pro comp AT's. i now run 37" toyo's, which are pretty close to 37" tall, mounted on 8.5" wide rims.
i too love the look of bigger rubber, and less lift.
04,3500,auto,silver Quad,4x4,62/475,air boss,TC rail,flux4.5,pusher,magnaflow,firepunk,Fass,gauges , mag hytec diffs and trans,air bags,amp reasearch,FF front bumper,welds,37"toyo MT,ATS flares,coolant bp,UDC,dual CP3,thuren,carli
pullinhard is offline
post #8 of 22 (permalink) Old 06-21-2011, 01:40 PM Thread Starter
thanks for all the info helps out alot i am thinking about getting the toyo
post #9 of 22 (permalink) Old 06-21-2011, 01:41 PM Thread Starter
keep ya posted
post #10 of 22 (permalink) Old 08-15-2011, 12:31 PM
mean_green's Avatar
I just put 37" toyo mt's on my megacab with 6" of lift and already tore up front air valance and the rear bedsides just are not wide enuf... after a weekend in the desert i have some deff paint damage....
BMF Led Light Bars
mean_green is offline
post #11 of 22 (permalink) Old 08-15-2011, 12:41 PM
silverrhino's Avatar
3" KORE with 37" toyo's
07 QCSB 4x4 Big Horn (5.9L) with DTT Trans, 5" magnaflow, AFE stgII, CFM+, Silver 62, Spearco CAC, Spool-Aid, Smarty TNT-R, Quad BF, AD 165, 3" KORE Race on 18" XD Hoss w/ 35" Nitto Trails.
silverrhino is offline
post #12 of 22 (permalink) Old 08-15-2011, 01:02 PM
cgmorgan06's Avatar
iTrader Score: 61 reviews
3" leveling kit and 37's on my old truck:
Grant
'06 black mega laramie 3500 srw 4x4, fully loaded, 6" superlift, 37" trail graps/22" M81s, AMP steps, true 5" custom duals w/7" tips, Autometers, ATS Stage 6 48re, II 85%, JL 150's, 62/480, HD push rods/springs, Spool Aid/GDP Air Boss/Grid Delete/ATS Arcflow, Airdog II, Amsoil bypass, Wicked coolant bypass, GDP Ladder Bars, Viair dual 480C, Nathan K3LA, Kenwood DNX 9140, JL 10's
560hp/1268tq 4/30/11
cgmorgan06 is offline
The Following User Says Thank You to cgmorgan06 For This Useful Post:
Dodge4829 (10-27-2011)
