What u-joints? - Dodge Cummins Diesel Forum
View Poll Results: Which u-joints?
Precision PUJ 464 5 14.29%
Spicer 5006813 26 74.29%
Dynatrac/Mopar V8016665AA 3 8.57%
Other? 1 2.86%
Voters: 35. You may not vote on this poll
post #1 of 13 (permalink) Old 06-12-2011, 12:02 PM Thread Starter
Shorts's Avatar
What u-joints?
Think I've gotta do u-joints. I have clicking somewhere up front. Predominantly heard when driving straight. Tough to hear when turning.
Which brand do you prefer?
2006 Ram 2500 QCSB 4x4 48RE 3.73 Leveled 285/70R17 CD AT3s H2s GDP MK2 Bilstein 5100s N62'd "AF" steering Custom Diesel brace MaxxLinks Modded stock airbox 4040XL
Shorts is offline
post #2 of 13 (permalink) Old 06-12-2011, 12:15 PM
Sneaux's Avatar
You should take it somewhere to have it checked out so your not throwing money at something that may not me the problem. If it is u-joints, lots of guys suggest these: Spicer 5006813 U Joint
I got my u-joints from Napa and they are greaseable.
07 QC 5.9, Thuren 3" coils, 35/12.5/17 mud grapplers, rancho 9000, silencer ring mia, debadged, Blue factory match gauges , diablo sport predator, FTE resonator, 08.5+ steering, PolyPerformance steering stabilizer, Carli track bar, BHAF, CFM+, 6000K Headlights, 3000K Fogs, Blue LED dash , Hertz High Energy sub and speakers all amplified
Sneaux is offline
The Following User Says Thank You to Sneaux For This Useful Post:
Shorts (06-12-2011)
post #3 of 13 (permalink) Old 06-12-2011, 12:17 PM
Sneaux's Avatar
Haha I didnt even see the poll up top
Sneaux is offline
post #4 of 13 (permalink) Old 06-12-2011, 12:23 PM
spicer and be done with it. get the spicer cheap from george at 8lugtruckgear.com
2005 Dodge Ram 3500 SRW 4x4 -2" leveling, 35 Nitto trail grapplers, Heavy Hauler trans, BHAF, Smarty TNT, FBD 5", ADII, Arson III, Flux 2 injectors, BD Killer B
Revolution is offline
The Following User Says Thank You to Revolution For This Useful Post:
Shorts (06-12-2011)
post #5 of 13 (permalink) Old 06-12-2011, 01:02 PM Thread Starter
Shorts's Avatar
Yeah, I'd hate to throw parts and labor at it and not fix the problem. I just went for a spin and the clicking is there up front. Halfway on my drive I stopped at the park and swapped out my center caps on the wheels to see if they were the culprit, but no dice, the clicking was still there. I crawled under and yanked on the axles and joints but really got no obvious movement from any ujoint on the truck throughout the entire driveline.
So I drove to Sonic to get a slush and frito pie. I'll work on that for right now
Shorts is offline
post #6 of 13 (permalink) Old 06-12-2011, 01:05 PM
carbon's Avatar
spicer is the only way to go, that is why every class 8 truck i know of comes with spicer from the fact.
carbon is offline
The Following User Says Thank You to carbon For This Useful Post:
Shorts (06-12-2011)
post #7 of 13 (permalink) Old 06-12-2011, 03:32 PM
for axle u joints I only use Spicer long life sealed u joints, everything else I use greeseable.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
The Following User Says Thank You to MPD106 For This Useful Post:
Shorts (06-12-2011)
post #8 of 13 (permalink) Old 06-12-2011, 05:15 PM
rgaskell's Avatar
Have to go with everyone else and vote for Spicer. Never had any problems with their product.
2016 3500 Asisn Megacab Stock for now
rgaskell is offline
The Following User Says Thank You to rgaskell For This Useful Post:
Shorts (06-13-2011)
post #9 of 13 (permalink) Old 06-12-2011, 11:46 PM
spicer.
I went thru 3 or 4 precision joints on my 01. precision has a plastic thrust plate/nossel that fails, not allowing grease into the cup. I drilled out the nossel on a friends courior truck about a yr ago and yester day I replaced his joints because they had up/down play, but as a first all the caps had grease in them, that has never happened on any other precision joint I have installed in courior trucks
I practice drilled this failed joint, then did it on a good one
this joint was greased every month !
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
The Following User Says Thank You to nickg For This Useful Post:
Shorts (06-13-2011)
post #10 of 13 (permalink) Old 06-13-2011, 08:07 AM Thread Starter
Shorts's Avatar
nickg, thanks for the pics. That's pretty ugly in there. Greased every month too!
On new u-joints are you suppose to put a little new grease in the caps? I saw that somewhere. I don't think I've done that on other ujoints but I will on these.
Shorts is offline
post #11 of 13 (permalink) Old 06-13-2011, 08:54 AM
no, do not add more grease to the cups, before assembly, the cups have pre-measured grease, on assembly DONT mix up cups, they must go back on the cross shaft they came off of. I use a paint pen and mark both the cross shaft and cup. I believe these warnings are on a sheet in the box the joint comes in (sheet no one reads)
the u-joints were greased every month (5000kms) as the truck was used for courior work, but at one point the nossel plugged up and grease never made it to the cup, so really it could have been along time before it made it there. the drv side has 520,000kms on the OEM (spicer) joint.
nickg is offline
post #12 of 13 (permalink) Old 06-13-2011, 09:46 AM Thread Starter
Shorts's Avatar
Ok - thanks!
Shorts is offline
