AC issue....a little different
Yesterday, I ran to the store about noon and found the passenger side vents blowing warm air, yet the drivers side was cold. So, I figured with everything I've read, that I need to add a little freon.
Well, it got a little more complex...The truck sat for about 2hrs, then I restarted it and had the engine idling (1000rpm, hi idle), while loading the camper, and found cold AC from drivers side and passenger side vents. The rest of the day, it was cold, like that.
Is this just an extension of the low freon symptoms?
Yes, the truck does have the split drivers/passengers temperature control.
Tony
1996 VW Passat TDI; Avg 43mpg
2006 VW Jetta TDI; Avg 35mpg
2006 3500 Dually, QC, LB, Laramie, Gauges 16.3mpg, last checked fwy mpg.
Reason: spelling
