06 tach issues - Dodge Cummins Diesel Forum
post #1 of 147 (permalink) Old 05-11-2011, 02:20 AM Thread Starter
oregonsandrat's Avatar
06 tach issues
I've been cursed with the 06 tach stepper motor failure. Does anyone have a part number for the replacement motor?
06 Ram 2500 CTD
oregonsandrat is offline
post #2 of 147 (permalink) Old 05-11-2011, 07:52 AM
KONG
1slo_CR's Avatar
iTrader Score: 6 reviews
What did it do before it failed? Mine drops at idle to 500 sometimes...
-2014 Ram 2500 MegaCab LIMITED, White, 3:42`s.
RIP- '6.5 RC SRW, GORILLA56r, SBC3850, 3.42`s, Hellman, Full Port/Polish, Floor-It Stg3.5, '10 #s-12.543@111.51 838hp/1691tq FUEL ONLY on a STOCK INTAKE HORN
-'10 Impulse Nytro 174
-'14 MPI Viper 141
1slo_CR is offline
post #3 of 147 (permalink) Old 05-11-2011, 09:44 AM
tinman23's Avatar
My tach does all kinds of jumping around at idle. Usually sits around 400 rpm, so I'm interested in a fix as well...
tinman23 is offline
post #4 of 147 (permalink) Old 05-11-2011, 01:35 PM Thread Starter
Sometimes it works flawlessly while more commonly is hangs 3-400 rpm less than it should, then while accelerating it will jump into the redline.
I know that GM had similar issues with poorly made stepper motors and it's a common issue with them.
The other option is to buy a new instrument cluster for $5- $600... Or a used one for $200 and still have a crappy stepper motor that will more than likely fail later on... Or have someone else do the repair for around $175.
I'm having a hard time choking those number down when the parts are less than $10 and soldering a motor into a board is fairly easy work and I can buy a better quality part at the same time.
I was hoping that someone had the stepper motor part # so I could get one ordered before I tear it down.
06 Ram 2500 CTD
post #5 of 147 (permalink) Old 05-11-2011, 07:56 PM
I figure for $600 ill live with my screwed up tach, ill put that $600 into other more important things that are broke also.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #6 of 147 (permalink) Old 08-13-2011, 10:49 PM
06speed's Avatar
I have spent countless hours searching for a stepper motor for these clusters with no luck. I wish someone would chime in that works in an electronics repair store.
I would love to find a motor and replace my tach motor.
'06 2500 4x4 QC, G56(MD-50wt)-ValAir Dual Disc, Jacobs ex.brk, crazy larry, Firestone ride-rite bags, Baldwin f/w sep + Cat 2mic filter, EV2-lift,rail,EGT,boost, MBRP 5" w/muff, OEM intake w/Banks Scoop
06speed is offline
The Following User Says Thank You to 06speed For This Useful Post:
Waveslider330 (08-04-2012)
post #7 of 147 (permalink) Old 08-14-2011, 01:07 AM
Dang. My tach is out too. Acted squirly as others above have posted, then finally died pretty much, unless I go above 75 mph, then it starts to read again, says motor is turning 4000 rpm.
Anyway, all this time I thought it was a simple sensor change out. But after reading this...it's the stepper motor and repair is $175-600????
2006 Ram 2500 CTD QC 4x4 3.73 Auto
CAR67 is offline
post #8 of 147 (permalink) Old 08-14-2011, 02:21 PM
Matafdo's Avatar
Mine goes all the way around, and pegs out on the stop needle.
06, 5.9, 2500, 4x4, Auto, QC, SB, RanchHand Front, Rear, GDP intake horn,Shibby delete, lines and rail, 2 1/2 level, fluidamper, 2nd Gen Swap manifold, Spyntec free spin, BW63/68/14, EFI(Anarchy Tuned), Carli BJ
Matafdo is offline
post #9 of 147 (permalink) Old 08-14-2011, 04:27 PM
Essington Avenue Auto
nick060200's Avatar
same problem...........waiting for a fix
06' 2500 QC SB 4x4, TRE Built 48re trans; EFI LIVE By cummins tuner; raptor 150; additional fuel filters; EV2 gauges x 4; 08.5 steering upgrade; 50hp MotorSport sticks
nick060200 is offline
post #10 of 147 (permalink) Old 09-12-2011, 10:11 PM
Found this in another thread and have read good reviews about them. Will likely send my cluster to them when I finally get sick of the dancing tach.
Mr. Whizard Technical Services - Instrument Cluster Repair, Speedometer Repair, Odometer Repair and Digital Dash Repair
SOLD '06 2500 5.9L, Auto, QCSB -- S&B CAI & intake horn, Smarty Jr., CAT 2 micron filter set up, Isspro Performax gauges, 5" TBE w/Donaldson muffler, 285/70/17 Terra Grapplers, 800 watt sound system w/ custom under seat sub enclosure.
Clockwork is offline
post #11 of 147 (permalink) Old 09-13-2011, 07:22 AM
nick060200's Avatar
where does it say they do dodges?
post #12 of 147 (permalink) Old 09-13-2011, 07:56 AM
06 tach issues-repair
Hello;
Mr. Whizard Here;
Yes we can repair the intermittent tach issues on the 2006 Dodge Ram. It is not a stepper motor problem but rather a problem in the circuitry of the cluster. Say you saw it here and receive $20 off of our regular repair price. If unit has been tampered with in any way then we cannot repair. Mr. Whizard Technical Services - Instrument Cluster Repair, Speedometer Repair, Odometer Repair and Digital Dash Repair
mrwhizard is offline
The Following 4 Users Say Thank You to mrwhizard For This Useful Post:
1slo_CR (04-17-2012), Ford Mechanic (08-17-2012), GoinKZ (09-13-2011), Ranch Hand (07-27-2012)
