Weird Vibration through steering wheel/brake pedal
So today my truck developed a bad vibration through the steering wheel and brake pedal. It happens the worst at low speeds while turning/braking or while stopped and turning the wheel. but goes away once I accelerate. I checked the power steering fluid, and its fine. I have no idea never felt anything like this before, any ideas?
06 Mega Cab, Auto, 6" lift, 37" tires, 5" TBE...pretty much stock
Sounds like a warped rotor or a bad caliper. After driving a good distance check to see if either of your rims are excessively hot. If so I would say its an issue with that caliper.
JoesEX, I'm having identical symptoms. Have you found the problem yet? When I get to work tomorrow, after about 15 miles at 65mph, I'll see if either of my wheels or hubs are hot in case a rotor or caliper is the culprit.
'06 Dodge Ram 3500, rebuilt AT, K&N intake, Banks exhaust, Bullydog programmer and power module, 35s on 20s, Ranch Hand rear bumper,
mine has been doing something very similar. vibrates inside the cab as well. mine started after my wreck. almost certain its not the rotors b/c it does it for me in park at below 1k rpm.. high idle it and the vibration goes away. not sure what it is?
Black 06 Laramie with: Smarty Jr, Isspro fuel-rail-boost-pyro, intake horn 2 MIC filter w/BIG line, 6in lift and 35s.
I just had this happen, replaced ball joints and ujoints in the front end. It went away. It was at low speeds, going over small bumps or slight turning. It felt like a shock was loose or something at first. Drove me crazy! Once I had help, I could see the ball joint movement on a dial indicator and feel it ever so slightly when I shook the wheel. I measured everything, track bar bushings, tire rod ends steering gear box.
Just offering up my experience might be that simple as ujoints and ball joints.
2006 Megacab 4x4 Lamramie, Nav, Sunroof, 48re, straight exhaust, Bilstiens 5100s, Leveling kit, 315s Duratracs, DIY intake not sure what to do next
