4WD indicator light switch replacement, how to with pictures - Dodge Cummins Diesel Forum
Old 01-31-2011, 07:24 PM   #1 (permalink)
Back story.
Bought the truck used last Feb, noticed that 4wd indicator light did not work. Dealer looked at it, said switch was bad and agreed to ship me the part, included in the sale. I got it and put it under the back seat of the truck, and just never put it in. So today there's a lot of activity in the 4wd indicator light doesn't work thread, so I decide I'll got put the switch in and see if it fixes the issue. The switch is a two wire switch with a weatherpak connector. Before replacing the switch, I did the bulb test by holding the reset switch and turning the key on, the light worked.
The part number for the switch is 05134375AA.
Tools needed
7/8 or 22mm combo wrench
Here's a pic of the new switch
Step 1, crawl under truck, lay with chest under trans crossmember, and look up between front driveshaft and transmission. You will see the switch on top of the transfercase. Here's what you'll see.
Step 2, use wrench to remove old switch, after wiping any debris away from it. I found the old switch was installed with no copper washer, "O" ring, or any type of seal, and is straight thread, not pipe. Interesting. Old and new.
Step 3, I decided that since it is a two wire switch, I'd put a little pipe dope on it as some form of seal. I then installed the new switch, plugged in the connector, crawled out from under the truck, and cleaned up my tools. Hopped in the truck, turned on the key, and put it in 4wd, here's the result. It works!
All said and done, it took about 15 minutes to replace the switch. I could have ohmed it out to see if it was good or bad before I swapped it, but since I had it, and don't have my meter here tonight, I figured I'd just swap it. I can post pics of how to check the switch if anyone is interested.
Scott
ferguson65 is offline   Reply With Quote
The Following 2 Users Say Thank You to ferguson65 For This Useful Post:
cornfedIA (02-02-2011), DennisNYS (01-31-2011)
Old 02-03-2011, 12:18 PM   #2 (permalink)
schoust's Avatar
Beutiful! It sure seems that it should have lasted more than 4 years!! How much was it and were did you get it from?Was it expensive?
07 QC 5.9 Big Horn 4x4 SRW Smarty
schoust is offline   Reply With Quote
Old 02-03-2011, 07:39 PM   #3 (permalink)
When I checked the truck over before I bought it, I saw it didn't work. The dealer looked at it, said the switch was bad and agreed to ship it to me on their dime, so I have no idea what it cost. I'd suggest a quick call to the local dodge dealer with the part number.
Scott
2007 3500 QCLB dually 6 speed 4x4, Mbrp, K&N, smarty JR, isspro gauges, B&W goose
Old 02-06-2011, 12:45 PM   #4 (permalink)
schoust's Avatar
Thanks Man! I have nothing but contempt for my steeler! I am looking for a place that I can get the parts on line so i don't have top deal with those people! Thanks for the help!
R
