What does it take to increase my lift kit from what I have? - Dodge Cummins Diesel Forum
Old 11-21-2010, 08:18 PM   #1 (permalink)
I have the fabtech 4.5 lift with those fancy external oil reservoir shocks, 4 up front and 2 in rear. The coils have a large limiting strap inside them where most peoples shocks are. mine are on a shock hoop outside the coil. In the rear I do not see a large block under the leafs. I do have airbags for loads, not sure if that has anything to do with lift in rear. I was wondering what would have to be done to get their 6" lift from my 4.5"? Just curious, not sure if I would do it, but want to see what is involved. Thanks
04.5 3500 laramie, afe intake, magna flow 5" exhaust w/6" tip, airbags in rear, fab-tech 4.5" lift w/ double shocks up front (dirt logic), w/37's now 35" grabber red letters, and some other junk
Loveday Electric is offline   Reply With Quote
Old 11-21-2010, 11:41 PM   #2 (permalink)
dayne808's Avatar
i have the same set-up you are trying to do. when i have time i'll take some pics and pm them to you.
2004 QCSB pavement pounder...sold
2005 6.0 Excursion LTD deleted and lifted...current family hauler
dayne808 is offline   Reply With Quote
Old 11-22-2010, 01:12 AM   #3 (permalink)
cool thanks
Old 01-06-2011, 10:31 PM   #4 (permalink)
top for responses
Old 01-07-2011, 01:00 AM   #5 (permalink)
Temple Diesel's Avatar
iTrader Score: 15 reviews
The cheap way would be to add a 2" spacer on top of the coil spring and 2" block in the rear.
2008 "Smurf" | ARP 625's | EFI & H&S OD Tuning | GUCCI Suspension
History
2006 Cummins Mega White/Black
2006 Cummins QC Red/Black July issue of Diesel World 11'
2002 Cummins Grey/Black best of 636/1198
Temple Diesel is offline   Reply With Quote
Old 01-08-2011, 10:45 AM   #6 (permalink)
tiny2085's Avatar
if you just add a 2" spacer in the front it will pull the axle back slightly without new control arms, I would call and see what the difference between the 4.5 control arms an 6" control arms are in length. If there is no difference, then just pop a 2 " puck on the coil spring
05' 3500 dually 4X4 QC 6 speed! - In for heart surgery !
93' cc srw 2wd - 60mm /sticks, 366 /pump tweaks
92 2WD SWB in the making...
tiny2085 is offline   Reply With Quote
Old 01-08-2011, 09:51 PM   #7 (permalink)
i would say u'll need longer controls arm's, get a set of adj ones and add blocks to the rear or new leafs, longer sway bar end links prob also and trac bar drop down bracket.....
03 QC 4x4, 6spd HO, 35/12.5 toyo m/ts. 20 hoss's, AEM Intake, Isspro's, Diablo predator & puck, BD super single, FASS Platinum 150, BD short throw, 5ft trac bars SOLD
95 reg cab 2wd, 5inch, gauges, 119k
cotton_87 is offline   Reply With Quote
Old 01-08-2011, 11:46 PM   #8 (permalink)
and maybe a new pitman arm
06' quad cab 4x4 bighorn Auto/4:10
4.5" fabtech lift, S&B CAI
305/65/R17 BAJA ATZ on Procomp 17x9 rims
Hiloram is offline   Reply With Quote
Old 01-09-2011, 11:36 AM   #9 (permalink)
JAMES VASQUEZ's Avatar
i just did what yall are talking bout this last weekend the only things you will need is lifted sway bar links i used suspension maxx cheap and great quality, longer link arms whick i got from top gun customz pretty cheap and theyll make them to any link you specify i had the 4.5 fabteck and stacked a daystar 2" coil spacer and they made me 7" link arms they were pretty quick about getting them to me as well, ull need longer shocks i went with bilsteins made a huge diffrence vs the febtech, but now i have a poping in the front end some where cant figure it out sounds like the springs are bottoming out but i know thats not the case, o and even though i had the longer sway bar links and the drop braket for the sway bar from the 4.5" kit i still had an issue with the sway bar being to far back and rideing on the coil springs so i modified the sway bar drop bracket i just welded a piece of flat steel 1/4" thick and drilled some hole took care of the problem
JAMES VASQUEZ is offline   Reply With Quote
