Oil Temp Guage Question...Help! - Dodge Cummins Diesel Forum
Old 11-01-2010, 04:42 PM   #1 (permalink)
Duallyman357's Avatar
i got some guages a few weeks ago and a buddy of mine installed them for me....but only 2 of them work...and the one that we couldnt figure out was the oil temp....is there some kind of adapter plate i need to get?
and if so what size do i need to get so far as the thread size goes?
any help is greatly appriciated....thanx
06 dodge dually, 4x4, lonestar ed., 6-speed man. trans, custom south-bend clutch, bullydog triple dog, strait-piped, k&n cold air intake, quadzilla boost fooler, glowshift guages, silencer ring MIA, leveling kit, pro comp shocks, mickey thompson baja atz's
Duallyman357 is offline   Reply With Quote
Old 11-01-2010, 05:16 PM   #2 (permalink)
Gear Nerd
TX_Dj's Avatar
Are you running an oil pressure gauge as well?
Look at the top of your (assuming you still have the stock) oil filter housing, see the little bolt on top? Try that location.
If you're also running an oil pressure gauge, you can probably plumb a Tee in there and run both senders on the same location.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
TX_Dj is offline   Reply With Quote
Old 11-02-2010, 01:27 PM   #3 (permalink)
well my truck comes stock with the oil pressure guage...i just need my oil temp hooked up
so what your trying to say is i can hook it into that little hole in the oil filter housing...ok...ill try that and see what happens....thanx for the info
Old 11-02-2010, 01:41 PM   #4 (permalink)
Gear Nerd
TX_Dj's Avatar
Sorry, you're mistaken.
The truck doesn't have an oil pressure gauge.
It has a "dummy gauge" that is designed to make you think it has an oil pressure gauge.
The stock oil sender is simply a switch that engages as long as you have 5 psi oil pressure. If you have 5 psi, and the engine is running, the ECM moves the needle on the gauge to an approximation of what it thinks your oil pressure should be for the temp and rpm. If you have less than 5 psi, the gauge reads zero and the CEL comes on with a code about low oil pressure.
Your real oil pressure is much different than what the gauge on the dash shows.
G56 / SBC SDD3250
