I started having turn signal issues, wrong signal coming on, both signals coming on, no signals at all. For the last month, the turn signal has worked correctly a total of 0 times. I had stopped using it all together, figuring no turning information was better than the wrong information.
I searched here and found it was a common problem. It seemed the only option was replacing the Multi Function Switch. With futher research, found that someone had solved the problem by pulling the MFS and cleaning it.
Well, I did this this three days ago, and the problem has completely gone away.
Here's what I did:
1. Removed the torx screw that holds on the tilt steering handle.
2. Removed the tilt steering handle
3. Removed the three torx screws that hold the steering column cowling together.
4. Removed the steering column cowling, it snaps apart rather easily.
5. Removed both negative battery cables (probably should have done this first)
6. unplugged the wires going to the MFS
7. Removed the two most visible screws to the left of the steering wheel (HINT: Make sure your steering wheel is turned to where you can get to both of these screws before disconnecting the batteries. I had to reconnect to so I could do this.)
8. Pull the MFS to the left, it is in there tightly, but it will snap out.
9. Remove the three small (tiny really) torx screws on the MFS. I had to go to Autozone because I didn't have a torx wrench small enough. The let me use it for free.
10. Remove the cover of the MFS by gently prying open the plastic tabs.
11. Wipe all the gunk off of the circuit board
12. Reassemble the MFS, snap it back in, put the screws back in, plug the wire back in, replace the cowling, put the tilt handle back on, reconnect the battery, and enjoy working turn signals!
Here's what I did:
