Cruise control vacuum question. - Dodge Cummins Diesel Forum
Old 10-24-2010, 09:12 AM   #1 (permalink)
As others have stated my cruis control would work fine until I tried to go up a hill or use the acceleration button. Once I did one of the two my cruise would kick off and not be usable again until I shut the truck off. I looked at my Vac. lines and found a hole in the line going under the driver side battery. I was like great I found the problem and fixed it quickly. I test drove the truck and to my dismay the problem is still there. All of this happend yesterday, I didnt look at it again until this morning but I inspected all of the lines and there are no more holes anywhere. I disconnected the line that I replaced yesterday and upon disconnecting it I heard a hisssssssss from a vacuum still being on the line so I guess the pump is working and the lines are hole free. Is this normal? When should the pump run? And also what is that thing that the 2 lines are going to under the driver side battery? Thanks in advance for the help
2004.5 Ram 2500 QC SB 4x4, CTD , Auto, Stock
As of 10/19/10 92k Miles
av8erdunn is offline   Reply With Quote
Old 10-24-2010, 03:29 PM   #2 (permalink)
Anyone got any ideas?
Old 10-24-2010, 06:01 PM   #3 (permalink)
tryNto's Avatar
Try unhooking both batteries for 1/2 hour, this sometimes helps strange problems...
03 QCLB 2500 HO CTD 6 spd/Fast Coolers 3.73 4x4 Atlantic Blue Pearl, S&B Filter/K&N Tube, Str8 pipe w/6" tip, "Pusher" Intake Horn, Adj. Boost Elbow, GDP 2mic Filter, Onboard Air w/ Horns, AutoMeter Boost & Oil Pressure.
tryNto is offline   Reply With Quote
Old 10-24-2010, 06:34 PM   #4 (permalink)
I tried that this morning but it didnt help.
Old 10-24-2010, 08:38 PM   #5 (permalink)
Dodgezilla's Avatar
iTrader Score: 16 reviews
That's your APPS unit which controls the cruise control along with the vacuum...
04 Ram 2500,Green/Silver 305/555HO,48RE,3:73s,QC,LB,4x4,Roadwire Leather Seats,Laramie Interior,Infinity Sound,HE351 Turbo,Custom 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan+180 Stat,Fogzilla,TRM,BFG AT 305/65s,72,000 miles
Dodgezilla is offline   Reply With Quote
Old 10-24-2010, 10:17 PM   #6 (permalink)
TXAustin's Avatar
Iv had this problem for a while. I changed the APPS after it went bad and it helped the problem some. While watching my Edge moniter throttle % I know it kicks off at about 30% throttle. I never have time to mess with the pump or lines to try and fix it. On highway trips I keep it the Smarty on tq3 and watch the hills so I can turn the cruise off before it reaches 25% (never gets that high though). So I'm good to go until I have time to fix the lines.
[04.5 QCSB] Jeff Garmon's Fat Shaft billet 48RE, 6" superlift, 37" Toyo M/T, XD Monsters, Super B Special/ S480 race cover, ATS twin pumps, II 65lpm (~250hp), ARP, Smarty SSR, AirDog 150, TC rail, 25k / 27k PRV's, Rail/fuel/EGT/boost/throttle%/load% gauges, Flex-a-Lite, 6" MBRP stacks, grid delete
TXAustin is offline   Reply With Quote
Old 10-25-2010, 07:16 AM   #7 (permalink)
I have noticed that I dont think my vac pump is running when the key is turned on. that makes me wonder why there was a hiss that came from the line when I disconnected it if the pump wasnt working?
