what should i be looking for if i have a bad fan clutch? i dont have any codes, but do have a ticking that sounds related to the fan i is not injectors valves etc it really sounds like the fan. all bolts are tight.
thanks for any info? also i heard cleaning the fan sensor connections sometimes helps? any input would be great thanks
03 qcsb black 4x4 UDC thuren bd r700 48re 10.2 stroker pump, STAGE 2 BBI's studs springs pushrods fully ported head banks side draft bd manifold intercooler fuel boss 2mic levis blankets
I've always check the fan clutch by spinning the fan. When you spin the fan you should feel some resistance. If you spin the fan and the fan spins fairly easy then the clutch is bad. If you spin the fan it it stops almost as soon as you spin it then the clutch is ok...Kind of a shade tree tech advice but it hasn't let me down yet....
04.5 Dodge 3500 Dually HO 5.9L Cummins, Automatic, Striker II Power Module, Cat 2-Micron Filter System, Holley Blue, AFE Pro-Dry S Air Filter, Gauges "Fuel Pressure, Trans Temp, Exhaust Temp", Muffler Delete Pipe>>"Still Tree Hugger Friendly"
You'll know by sound if your fan clutch is working, that's a massive fan, it moves a lot of air. It will tend to cycle when the truck is warm, especially if you turn the AC on or off. It will also tend to sound like a hurricane under the hood when fully engaged and driving off slowly from a start. Mine does it every morning when the truck is cool, you can hear the fan just blowing hard as you start to take off, and then it sounds like the engine is revving higher but the fan cuts back.
The other advice is good too.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
Just a heads-up....
if you isolated that ticking sound to the fan/clutch, keep an eye on it.
That was an indicator just before mine went. I was told it was the bearing
going bad.
