How To: Make HIDS work w/ Resistors - Dodge Cummins Diesel Forum
View Poll Results: Was this thread Helpful?
YES 63 84.00%
NO 5 6.67%
A LITTLE 7 9.33%
Voters: 75. You may not vote on this poll
post #1 of 226 (permalink) Old 08-11-2010, 04:16 PM Thread Starter
03 Rammer's Avatar
Lightbulb How To: Make HIDS work w/ Resistors
*If you have a hid kit that is hid low and halogen high, You will not need to do this. Simply buy some capacitor packs and install. Check out the thread Hid for dummies for further help.
Bixenon kits only follow this below, i.e. hid lowbeam hid highbeam
Supplies needed:
1. HID kit
2. 2 or 4 6/8ohm 50 watt resistors (depending on single/dual beam HID kits)
3. 2 9007 female connectors
4. Thermal tubing
5. Butt connectors/Solder
6. Heat shrink
First install the HID kit you bought. Test it out, If you experiance flickering, strobing, flashing, turning on and then turning off, LAMP OUT light etc. You will need to do the following.
*** IF you do not want to use resistors that's fine there are other ways such as using Caps or buying a more expensive HID kit.
NEXT starting with the easy part, the Passenger side unused plug.
With this side all your doing is tricking the FCM as to if there is a 50/55watt bulb there. Simply use a 9007 connector and add the resistors to both beams or just one beam.Then ground it.
Pictures of this:
Plug it in and and test the lights again...
***REMEMBER RESISTORS DO GET HOT SOO DON'T TOUCH WHEN ON AND WATCH WHERE YOU MOUNT THEM AT
***If you still have any issues follow the next steps.
Moving on to the driver's side.
This is where you have a few ways of doing this but I will describe mine.
Do the same thing as you did on the passenger side. Then take the wiring from the HID kit and follow the following picture.
Pictures of this:
Once this is done connect it to the trucks 9007 male connector and test it out. At this point you are done and the lights should work.
IN A NUTSHELL:
HELPFUL LINKS
IF YOU DON'T WANT TO MAKE THESE YOU CAN BUY THESE PRE MADE FROM HERE:
50W Resistor Plug Play Pack
Don't know what bulb your truck has, visit the below link:
OSRAM SYLVANIA - Replacement Guide - Start
CONFUSED AS TO HOW THE WIRING GOES TOGETHER WITH YOUR NEW BI XENON KIT?
http://www.sunny-shine.com/epic/20110525102858.jpg
GOOD HID FOR DUMMIES F.A.Q. (WRITTEN UP BY SUNNY SHINE LIGHTING CO)
F.A.Q-Sunny Shine Lighting Co., Ltd.
2003 Dodge Ram 2500 Silver Laramie 4x4 My Useful Threads: How To: Make HIDS work w/ Resistors, How To: Tint your Tails, Weak Hood Shocks???
HID QUESTIONS YOU ASK....ASK
03 Rammer is offline
The Following User Says Thank You to 03 Rammer For This Useful Post:
dukelubas (05-31-2013)
post #2 of 226 (permalink) Old 08-11-2010, 04:19 PM Thread Starter
03 Rammer's Avatar
Troubleshooting
If you still have issues after installing the HIDs dont worry.
Simply try swapping the wires for the high and low beams, and try again.
If you still have any issues check all your wiring and connections.
NO GO? shoot me a PM, I will try to help as much as possible.
post #3 of 226 (permalink) Old 09-25-2010, 01:24 PM
sycho's Avatar
soooo... would you be interested in making me the harness w/ resistors i need to make this work? i appreciate all the help you have provided thus far
06 Dually, Bully Dog, 5 inch MBRP
93 gmc typhoon
sycho is offline
post #4 of 226 (permalink) Old 09-25-2010, 03:16 PM
sycho's Avatar
my radio shack does not stock the resistors needed does anyone have a part # for them and also know where i can get the 9007 connectors nedded?
93 gmc typhoon
sycho is offline
post #5 of 226 (permalink) Old 09-25-2010, 03:57 PM Thread Starter
03 Rammer's Avatar
Yeap I could of told you that. I ran into the same problem they are large resistors and no place local for me carried. You will have to get them off ebay.
Just search 6-10 Ohm 50 Watt resistors.
post #6 of 226 (permalink) Old 09-25-2010, 04:31 PM
sycho's Avatar
thanks once again!
93 gmc typhoon
sycho is offline
The Following User Says Thank You to sycho For This Useful Post:
03 Rammer (09-25-2010)
post #7 of 226 (permalink) Old 09-25-2010, 07:24 PM
Shup1's Avatar
superledlights.com
i believe they have the ledís and resistors
2006 2wd Mega cab-/160k
Shup1 is offline
post #8 of 226 (permalink) Old 09-25-2010, 09:57 PM Thread Starter
03 Rammer's Avatar
Originally Posted by Shup1 View Post
superledlights.com
Yes they sell the resistors aswell, but for more money than I paid.
post #9 of 226 (permalink) Old 09-25-2010, 11:49 PM
Thanks for the write up. I'm still a little confused though, if I was to use a harness uses the factory switch to power a relay wired directly to the battery so that the lights actually get power from there do I still need resistor's in place? Here is the harness I'm talking about
suvlights.com Universal Heavy Duty Headlight Wiring Harness w/ relays for bulbs (9003/H4, 9004
2006 2500 4X4 cc Big Horn. 5in Exhaust, AFE intake Horn, Cold Air intake, Built Trans, more on it's way
Sputter is offline
post #10 of 226 (permalink) Old 09-26-2010, 10:00 AM Thread Starter
03 Rammer's Avatar
Yeap you'll still need resistors. This is the harness that I used that came with my HIDS...
The harness is for the HIDS inital turn on which for the DDM tuning light is about 6amps and also powers the Hi/low magnet. You are still using your factory lighting set up which connects to this harness and the controls work as a trigger switch for the light to work.
With resistors all your doing is tricking the FCM to simulate a good working 50/55 watt bulb for both beams.
post #11 of 226 (permalink) Old 09-26-2010, 01:54 PM
Shup1's Avatar
True but if you can't find them anywhere else....
Shup1 is offline
post #12 of 226 (permalink) Old 09-26-2010, 03:46 PM Thread Starter
03 Rammer's Avatar
Very true but they are all over Ebay.
