Mopar Severe Duty Filtration Kit - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 08-06-2010, 02:05 PM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
Does anyone have this?
I am looking for the part numbers for the harness as well as the fuel heater.
Thank you.
AH64ID is offline
post #2 of 23 (permalink) Old 08-06-2010, 10:21 PM
I am assuming this is a mopar fuel filter? I know they have a new heavy duty air filter thats pretty damn good.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #3 of 23 (permalink) Old 08-06-2010, 10:22 PM
SNAFU
twhetten's Avatar
iTrader Score: 7 reviews
from what I saw on the pricing on that you can build or buy an aftermarket system for way cheaper, and it looks like it only filters down to 5 microns
The road goes on forever and the party never ends
twhetten is offline
post #4 of 23 (permalink) Old 08-06-2010, 10:26 PM
SNAFU
twhetten's Avatar
Qty. Part No. Description
1
(AR)
68046192AA Kit, Severe Duty Fuel Filtration - DC 143.5 & 167.5 WB 52 Gal
Fuel Tank - 6.7L
1
(AR)
68046193AA Kit, Severe Duty Fuel Filtration - DC 143.5 & 167.5 WB 22 Gal
Fuel Tank - 6.7L
1
(AR)
68045251AB Kit, Severe Duty Fuel Filtration - DH/D1 140.5 & 160.5 WB 34
Gal Fuel Tank - 6.7L
1
(AR)
68045252AA Kit, Severe Duty Fuel Filtration - DH/D1 140.5 & 160.5 WB 35
1
(AR)
68046206AA Kit, Severe Duty Fuel Filtration - DC 163.5 WB 52 Gal Fuel
Tank - 6.7L
1
(AR)
68046207AA Kit, Severe Duty Fuel Filtration - DC 163.5 WB 22 Gal Fuel
Tank - 6.7L
1
(AR)
68045253AB Kit, Severe Duty Fuel Filtration - DH/D1 140.5 & 160.5 WB 34
Gal Fuel Tank - 5.9L
1
(AR)
68045254AA Kit, Severe Duty Fuel Filtration - DH/D1 140.5 & 160.5 WB 35
1
(AR)
68051906AA Kit, Severe Duty Fuel Tank Ventilation - DC 52 Gallon Tank
1
(AR)
68061341AA Kit, Severe Duty Fuel Tank Ventilation - D1/DH 35 Gallon Tank
1
(AR)
68061342AA Kit, Severe Duty Fuel Tank Ventilation - D1/DH 34 Gallon Tank
1
(AR)
68061633AA Element, Fuel Filter - Shell and Filter (5 Micron)
1
(AR)
68061634AA Element, Fuel Filter - This filter to supersede the original
5183410AA filter when supplies are exhausted
twhetten is offline
post #5 of 23 (permalink) Old 08-06-2010, 10:28 PM
so what exactly is this kit?
MPD106 is offline
post #6 of 23 (permalink) Old 08-06-2010, 10:31 PM
SNAFU
twhetten's Avatar
here is what the TSB I pulled off another site says
SUBJECT:
Heavy Duty Filtration - MOPAR Retrofit or Add On Parts Available
MODELS:
2004 - 2009 (D1/DH) Ram Truck (2500/3500 Pick Up)
2007 - 2009 (DC) Ram Truck (3500 Cab Chassis)
NOTE: This bulletin applies to D1/DH vehicles equipped with a 5.9L Cummins engine
built after January 1, 2005 and D1/DH/DC vehicles equipped with a 6.7L
Cummins engine built from 2007 model year (sales codes ETH, ETJ).
DISCUSSION:
Several fuel system add-on or retrofit parts are available to enhance the filtering capability
for customers exposing their vehicles to extremely dirty conditions.
Description of parts available for Cummins diesel equipped vehicles are listed below:
5.9L & 6.7L Water stripping, frame mounted filter kit. This kit includes the following:
revised lift pump, lines, heater, water in fuel (WIF) sensor, and instructions.
6.7L up-graded (5 micron) fuel filter to retrofit earlier models (shell and element).
6.7L Element only, fuel filter.
5.9L & 6.7L Add-on or up-graded fuel tank vent hose kit with vent cap.
NOTE: Several parts will be added to this bulletin when they are available. The
bulletin will be revised when they become available. These parts include a
Filter with Bracket assembly which will replace the cap on the fuel tank vents
for all the above vehicles, a 5 micron fuel filter for 5.9 engines and an
improved air filter for 5.9 engines.
NOTE: The maintenance intervals for the fuel filters (engine mounted filter and
chassis mounted severe duty fuel filtration kit filter) maintain a 15,000 mile
service requirement for both.
twhetten is offline
post #7 of 23 (permalink) Old 08-06-2010, 10:43 PM
I bet you can buy an air dog and a gdp 2 micron kit for the same price or less than that. I noticed they have the new mopar heavy duty air filter included in that.
MPD106 is offline
post #8 of 23 (permalink) Old 08-06-2010, 10:58 PM
Pooter's Avatar
Yeah, but at least with the mopar kit theres a small chance they might still cover something under warranty if it happens(Yeah, I know, a snowballs chance in....)
As for the cost, I dont even want to know.
'12 Ram 2500 CC 6.7/Auto/4wd - AFE drop in, Raceme, EGR Delete, Flo Pro 4" TBE, 17x9 Addicts 285/75/17 Nitto HTs, Reverse Leveled, Bilstein 5100s, 5" Iboard Steps
Pooter is offline
post #9 of 23 (permalink) Old 08-06-2010, 11:08 PM
SNAFU
twhetten's Avatar
from what I read it is about $750
twhetten is offline
post #10 of 23 (permalink) Old 08-07-2010, 10:25 AM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
I have the TSB, and I already have 3 fuel filters on the truck. I am looking for part numbers on some components of the kit, not the kit itself. I want to add the fuel heater and 2nd WIF sensor.
So I need someone who has the kit to look at their parts or owners manual.
The kit is an upgraded lift pump, 10um f/w sep, 2nd WIF sensor, and fuel heater. Its a good kit, but not worth the $750. The OE LP is adequate for 3 filters, I know I am doing it; and I have much better filtration than this offers for much less, with a gauge.
AH64ID is offline
post #11 of 23 (permalink) Old 10-19-2010, 08:57 PM
kruisecontrol's Avatar
iTrader Score: 5 reviews
heres some pics for future reference 68045254 aa
i bought one for 250 here locally ,the guy had some more left.
2003 DODGE RAM 1500 CC CUMMINS 4BT / 47RH / HY35
2002 F250 CC LB MBE 190 4 CYL (IN PROGRESS)
2003 FORD EXCURSION LIMITED 4X4 07 5.9 CR CUMMINS 48RE AIRDG MBRP SMARTY
kruisecontrol is offline
post #12 of 23 (permalink) Old 10-28-2010, 03:05 PM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
$250?
Do you have contact info?
AH64ID is offline
The Following User Says Thank You to AH64ID For This Useful Post:
EME 411 (06-09-2012)
