A/C Compressor Clutch Bearings - Dodge Cummins Diesel Forum
Old 07-29-2010, 12:54 PM   #1 (permalink)
I have a squeak noise coming from a bearing in my A/C clutch. I removed my belt and spun the pulley and it did not spin freely like it should. How hard is it to remove? In the service manual it says you need a couple of special tools. How expensive is a new compressor? My A/C doesn't work the greatest either. It seems to frost up. The airflow in the cab will slow down until I shut the A/C off and then it will speed up after it thaws out. Is it too low on refrigerant?
'03 2500 QC LB 4x4 6sp Smarty JR, FASS 150/95 3 mic, Timbrens, Modded air box, DPP Cool Hose, DT Free-Spin, Centramatics, Cooler Tubz, HE351, ATS ex man, 4" farmer exhaust, 138,000 mi 35psi+ 1250F on Perf '92 W350 w/ Hydra-Dec sticks, 16cm, & Cooler Tubz
CRToney is offline   Reply With Quote
Old 08-01-2010, 10:51 AM   #2 (permalink)
On my 06', I am currently working on some AC problems. You can remove the compressor in 20-30 mins. Just evac your system and there are 4 13mm bolts, you'll need a socket with 12" extention to get the top 2 bolts and a 13mm wrench to get the bottom 2. The AC lines are held in by 1 10mm bolt, a wrench will work fine. Pull it out the bottom...pretty simple process.
There really is no telling what the problem is with your AC.....these have the worse system I have ever come across.
Good luck getting it fixed sir, sorry I couldn't offer anymore help.
J.R.
1stz06 is offline   Reply With Quote
Old 08-01-2010, 10:55 AM   #3 (permalink)
Also, there are a few members that I have come across who have purchased rebuilt compressors from a place in Dallas called Gold Auto Recycling for $140 w/ 1 or 2 year warranty. I didn't use them but it may be worth checking out.
GL
J.R.
