A/C clutch doesn't engage - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 06-23-2010, 10:33 AM Thread Starter
The other day I was driving down the road 07 2500 5.9 got on it and all of a sudden it from blowing cold air too hot. Now the clutch won't engage on the compressor. You can sit in the truck at a idle and hit the A/C button and here it try to engage but it wont. Anybody have any idea's on what could be worng?
07 2500 4X4 Quad Cab
5" exhaust, AFE Stage 2 Intake, Garmon tranny, isspro guages, topgun 3.5 lift, 35's, 63/65 fleece, efi tuning
TheJones is offline
post #2 of 19 (permalink) Old 06-23-2010, 10:48 AM
Master of Mayhem NASFIG
rpage's Avatar
either your compressors bad or your low on freon
Really don't give a rat's App**
rpage is offline
post #3 of 19 (permalink) Old 06-23-2010, 11:03 AM Thread Starter
Checked the freon the other day for some reason i had a guy recharge it and that dum*ss had it charged plum up in the red after that is when the clutch quit engaging
TheJones is offline
post #4 of 19 (permalink) Old 06-23-2010, 11:06 AM
cgmorgan06's Avatar
iTrader Score: 61 reviews
ohm out the clutch coil on the compressor and make sure that it is still good
Grant
'06 black mega laramie 3500 srw 4x4, fully loaded, 6" superlift, 37" trail graps/22" M81s, AMP steps, true 5" custom duals w/7" tips, Autometers, ATS Stage 6 48re, II 85%, JL 150's, 62/480, HD push rods/springs, Spool Aid/GDP Air Boss/Grid Delete/ATS Arcflow, Airdog II, Amsoil bypass, Wicked coolant bypass, GDP Ladder Bars, Viair dual 480C, Nathan K3LA, Kenwood DNX 9140, JL 10's
560hp/1268tq 4/30/11
cgmorgan06 is offline
post #5 of 19 (permalink) Old 06-23-2010, 11:10 AM Thread Starter
Compressor isn't froze up but it is at the dealership right now. I was gonna try and use a piece of wire too see if the would make it engage. Could it be that the magnets that are inside of it are wornen down and to far apart that it is trying to pull too much juice too engage the compressor that it just shuts it down
TheJones is offline
post #6 of 19 (permalink) Old 06-23-2010, 11:21 AM Thread Starter
I am hoping that it is a easy fix. Hoping its not some kind of wire that is shorted out.
TheJones is offline
post #7 of 19 (permalink) Old 06-23-2010, 11:30 AM
Cummins Newbie
rebel102285's Avatar
OK So... I'm having the same problem... To recharge the A/C I have to get the compressor engaging correct? if so how should i do it? jump a hot right to it and try that?
2006 Ram 3500 Mega Cab: Twin Turbos Hx-35 over an Ht3b with 2nd Gen Manifold, Byrds Intake Horn, 5" Turbo Back Exhaust, Boost Fooler, Smarty S06 POD with TNT Revo Tune, Isspro Performax Gauges, ATS Stage IV Transmission, Billet Flex Plate, AirDog II Fuel Preporator 165GPH, lndustrial Injection 90hp Injectors, Hamilton 110# Springs, Hamilton Billet Pushrods, Ported and Polished head
rebel102285 is offline
post #8 of 19 (permalink) Old 06-23-2010, 11:34 AM Thread Starter
I couldn't tell ya on that im dumber than rocks when it comes to working with the a/c cause mine was working great and then just quit the clutch wouldn't engage anymore
TheJones is offline
post #9 of 19 (permalink) Old 06-23-2010, 11:41 AM Thread Starter
I wish somebody knew if it was my compressor that was bad or something else
TheJones is offline
post #10 of 19 (permalink) Old 06-23-2010, 11:45 AM
Cummins Newbie
Same Here... What I am going to do is jump a hot wire to the A/C Compressor and get it to kick on.... then recharge it... If that doesnt work i will find the "low Pressure Switch" and jump/short it out to see if thats the problem...
From What ive been reading i hope mine is just low on R134
post #11 of 19 (permalink) Old 06-23-2010, 11:48 AM Thread Starter
Well I know mine isn't low so its either in the wiring or the compressor is shot
TheJones is offline
post #12 of 19 (permalink) Old 06-23-2010, 11:49 AM
Cummins Newbie
Check the low pressure switch.... im not sure wher it is but to rule if its bad or not just jump a wire across it
