Right front tire side to side movement - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 03-25-2010, 08:53 PM Thread Starter
mikenyc14's Avatar
Jacked up truck today to rotate the rubber and the right front tire wiggles slightly from side to side but not up and down. I found the play where the steering linkage connects to i think its called the spindle? Does the entire linkage have to be replaced or can it be bought in pieces? How much and how hard to fix?
06' 2500 , 4X4, SRW Quad cab, Smarty Jr., 305/65/17, Pro Comp Extreme A/T`s built trans, 269k miles.
mikenyc14 is offline
post #2 of 7 (permalink) Old 03-25-2010, 09:57 PM
EME 411's Avatar
2 or 4 whl dr?
2012 3500 CC 4X4 SLT LBSRW Auto /H&S MM(Guages Only)/Toyo AT 285-70-17/Air Bags/Rancho Shocks/ Hellwig sway bar/ Maverick M1000 Truck Camper/Sold 06 Mega Cab 2500 4X4 w/Fisher Plow. Retired CDN ARMY Veh Tech Living The Dream
EME 411 is offline
post #3 of 7 (permalink) Old 03-25-2010, 10:09 PM Thread Starter
mikenyc14's Avatar
Its a 4X4.
post #4 of 7 (permalink) Old 03-25-2010, 10:56 PM
EME 411's Avatar
Go to Download PDF Dodge | PDFTown.com and down load the manual. The play could be in any tie rod end, ball joint or possible whl bearing. Get under the veh not running and have someone wiggle the steering wheel left to right and you should be able to determine where the excessive play is. I hope this helps and it anyone else has more insight on this - step up to the bar. As far as parts cost that's a good question which can't be answered until you know what has to be replaced plus whl alignment.
EME 411 is offline
The Following User Says Thank You to EME 411 For This Useful Post:
mikenyc14 (03-26-2010)
post #5 of 7 (permalink) Old 03-26-2010, 12:24 AM
SandyMushCummins's Avatar
The parts can be changed individually, but check them all thoroughly because chances are good that more than one are worn. You can replace most of them without too much trouble or special tools, but as stated above, you'll want a wheel alignment.
'07 2500 ThunderRoad QC 4x4, 5.9, G56, 3.73's, S&B airflow pack, ISSPRO gauges, 2.5" mini-lift, Power Wagon flares, 295/70/17 Dynapro RF-10's, 90k miles as of 6-15.
SandyMushCummins is offline
The Following User Says Thank You to SandyMushCummins For This Useful Post:
post #6 of 7 (permalink) Old 03-26-2010, 07:21 PM Thread Starter
mikenyc14's Avatar
The only thing with a little play is the tie rod end closest to the right front wheel.
post #7 of 7 (permalink) Old 03-26-2010, 08:18 PM
Awesome. I have successfully estimated front wheel alignment when changing a tie rod end by counting the exposed threads on the center link before removing the old one and leaving the same number exposed when installing the new part, but you are relying on the precision of the machining, and 315/70/17's are pricey.
