Wiring the lights on a Headache Rack - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 03-20-2010, 04:08 PM Thread Starter
Diesel Junkie
1-TON's Avatar
iTrader Score: 10 reviews
Has anyone wired up a Lighted headache rack? If so could you possibly tell me what wires and where you spliced into them. I dont really want to run extra wires from the tail lights back to the headache rack. Pictures would help as well. Or a website that tells how to do it. TIA
JAMES 2002 RCLB 4x4, NV56, Flow-Pro 4" TB.
"The Work Truck"
1-TON is offline
post #2 of 11 (permalink) Old 03-20-2010, 04:37 PM
Mingle's Avatar
Going into your trailer plug would be the easiest I'd say.
You should be able to follow the wires from your plug back up the frame.. and hook to them halfway at least.. between where the bed and cab meet.
Just an idea.
'99 2500 24V. Auto. AD100. Quadzilla Adrenaline, 4" turbo back (straight piped), BD-Power HPVP44, BD Stealth Plate, Boost Elbow. Built Trans.
Mingle is offline
post #3 of 11 (permalink) Old 03-20-2010, 05:21 PM Thread Starter
Diesel Junkie
1-TON's Avatar
Thanks for the idea.
"The Work Truck"
1-TON is offline
post #4 of 11 (permalink) Old 03-20-2010, 05:22 PM
Mingle's Avatar
Is it just the standard lights? Brake, turn, and reverse?
Mingle is offline
post #5 of 11 (permalink) Old 03-20-2010, 07:56 PM Thread Starter
Diesel Junkie
1-TON's Avatar
Yes. It has 1 red and 1 white LED per side. Wanting to have the tail, stop, turn, and reverse
"The Work Truck"
1-TON is offline
post #6 of 11 (permalink) Old 03-20-2010, 08:21 PM
07Bighorn's Avatar
Just an idea.
The 4way plug is a good way to tap into, since its not used if you have a tow package, you can just plug in a 4 wire trailer kit and wire it to the lights with no splicing.. most of those come color coded yellow green and brown and about 25' lenght...
07 Dodge 2500 Big Horn 5.9L... AFe Stage2 Cx Pro Dry S, WinSpeed heater delete, MRBP cat delete.... Quad boost Fooler 296.7hp baseline. 2" leveling kit with Ion 133 wheels wrapped with 35" Nitto's and wants a playmate for my stock turbo!
07Bighorn is offline
post #7 of 11 (permalink) Old 03-20-2010, 08:58 PM Thread Starter
Diesel Junkie
1-TON's Avatar
Thats exactly what I am planning on doing. Just gonna have to find the reverse light wire.
"The Work Truck"
1-TON is offline
post #8 of 11 (permalink) Old 03-20-2010, 10:59 PM
Mingle's Avatar
If it's an automatic it should be easy to follow from the reverse light switch on the side of the tranny.
Mingle is offline
post #9 of 11 (permalink) Old 03-21-2010, 12:23 AM
06 Cummins
iTrader Score: 5 reviews
I used the 4-way plug to wire mine up. I did not bother with using white backup lights up on the rack, wired up two led tail light instead. I considered tapping into the factory wire harness along the frame, near the cab/bed junction, and installing a 4-way plug there, that way ifI had to remove the headache rack I could just unplug it close by the rack. I twas just easier to run a trailer cable along the frame and tie it up with some ty wraps.
Tranny reverse light switch or pick up the reverse light wire off the 7-way if you are running it from the back would be what I'd do. They DO offer a 6-way flat wire or a round 6 conductor cable for trailer wiring also.
CD
2006 Dodge 3500 MC DRW 4x4 6-spd 3.73 LS rollin' on 19.5's. Not stock by any means . .
CD in NM is offline
post #10 of 11 (permalink) Old 03-22-2010, 06:16 PM Thread Starter
Diesel Junkie
1-TON's Avatar
Well I got them installed. I just hard wired them into the factory harness. Ill get some pictures up later.
"The Work Truck"
1-TON is offline
post #11 of 11 (permalink) Old 03-23-2010, 06:17 PM
macko300exc's Avatar
i got this for my goose neck Reese OEM Quality In Bed Trailer Wiring Plug Adapter for 2000 -2008 Dodge
it allows you to put a 7 way in the bed. then i got another one of the harness without the trailer plug for $20. and went from the gn plug to the headache rach. since my lights are LED's i wasnt concerned about puttin too much load on truck, trailer lights are LEDs too.
macko300exc is online now
