cat filter base?? - Dodge Cummins Diesel Forum
Old 03-10-2010, 06:54 PM   #1 (permalink)
cat filter base??
i was wondering what push lock fittings i need to hook my cat 2 micron filter base up? im running a airdog which im going to put the cat setup between the airdog and stock filter houseing
2005 Dodge Ram 3500 SRW 4x4 -2" leveling, 35 Nitto trail grapplers, Heavy Hauler trans, BHAF, Smarty TNT, FBD 5", ADII, Arson III, Flux 2 injectors, BD Killer B
Revolution is offline   Reply With Quote
Old 03-11-2010, 08:36 PM   #2 (permalink)
come on guys someone must know this>
Old 03-22-2010, 03:22 PM   #3 (permalink)
what did you guys use?
Old 03-22-2010, 03:40 PM   #4 (permalink)
8mpg's Avatar
-12orb to 3/8" push lok
8mpg is offline   Reply With Quote
Old 03-23-2010, 07:12 PM   #5 (permalink)
i tried a -12 orb and couldnt get it to thread into the base? it is too big?
Old 03-23-2010, 08:30 PM   #6 (permalink)
8mpg's Avatar
Cat and Fleetguard use a -12o-ring boss. Other setups out there including the Wix base and Permatex base use a 1/2" NPT. The 1/2"NPT is a bit smaller. Just take the filter base to a plumbing/hydraulic shop.
Old 03-24-2010, 09:22 PM   #7 (permalink)
bigramdiesel's Avatar
filter base
My filter base used a -10 orb
2003 Dodge Ram 2500 Diesel HO, 48re Trans, KORE Chase suspension, Carli cotrol Arms, 09 Mopar steering Up-grade, TOYO 35x12.2x17 M/T, Banks Exhaust, ATS Exhaust manifold & air intake, Amsoil Oil by-pass filter, 2micron fuel filter, trans & coolant filter
bigramdiesel is offline   Reply With Quote
Old 03-24-2010, 09:32 PM   #8 (permalink)
Check this sight: Installing additional fuel filters, GDP w/ Cat 2 Micron, and a Fuel/Water Sep....
Old 03-24-2010, 09:35 PM   #9 (permalink)
Check this sight: DIY aftermarket fuel filter guide
Old 03-24-2010, 10:47 PM   #10 (permalink)
avatar challenged
mikeshauling's Avatar
The 10 ORB is what fits these cat heads. Then you need that to go to the size of your lines. 1/2 in. most likely since you have the AD. Also read the threads that are posted above, lots of good info in them.
2012 4X4 CCLB DRW Mini Maxx non deleted tune , for now !
Firestone ride right airbags, duraflaps,
mikeshauling is offline   Reply With Quote
