help no low beams - Dodge Cummins Diesel Forum
Old 02-23-2010, 03:57 PM   #1 (permalink)
smokin6spd's Avatar
help no low beams
my cousin has an 07 dodge mega cab with no low beams anyone ever run across this problem
2009 2500 6 spd g56, SB dd 3250 and hydros, EFI by kory willis, sd manifold 467/83/.9ar,source swap kit, autometer fuel boost egt, arp 425,5" TBE,bod intake manifold,banks Intercooler, air dog 150, vulcan drawstraw V, 6 inch bds short arm lift, fox shocks, bmf death metal / toyo oc , bushwacker flares
1999 2500 auto 4 mbrp inch exhaust, intake, edge comp box,bd stealth cover, raptor 100 1/2in lines, 8ft hiniker plow, fully built trans by the old man with billet tripple disc from pro torque and a whole load of goodies from sun coast and transgo , reading utility cap.
smokin6spd is offline   Reply With Quote
Old 02-23-2010, 07:01 PM   #2 (permalink)
carson b's Avatar
first off make sure its not the lights, if its not your truck you never know if your cousin had a light out for a wile and never noticed then the other side went out , i say this because my brother has had this happen not once but twice, and if all is good then check the fuses under the hood to see if they are good and have power to them and if there is nothing there look at the switch inside if there is power coming in and out
2001 dodge 3/4 ton 6 speed 4x4
4 inch bd exhaust with engine brake
edge juice computer and bd cold air intake
carson b is offline   Reply With Quote
The Following User Says Thank You to carson b For This Useful Post:
smokin6spd (02-23-2010)
Old 02-23-2010, 07:07 PM   #3 (permalink)
i had the same problem and both of my low beams on my bulbs were blown. it could also be the switch inside.
03 2500 with 22"eagle alloys, 37x13.5 mud grapplers, 200hp injectors, banks intake, isspro ev2s,ats 2 piece ex manifold,s372, beta 4.2,mp-8,fass 150, evil twin cp3s ,arp 425s,Hamilton 181/210,dtt tranny,dynatrac Bj's and 4"dual exhaust
dieseldog863 is offline   Reply With Quote
The Following User Says Thank You to dieseldog863 For This Useful Post:
Old 02-23-2010, 08:02 PM   #4 (permalink)
smokin6spd's Avatar
i checked everything with a power probe the bulbs are good we changed them just to be safe we have jucie to the switch all fuses are good but my all data through my shop said the head lights run through the pcm what do i do
Old 02-23-2010, 09:37 PM   #5 (permalink)
smokin6spd's Avatar
i was told that it could be the cluster anybody
Old 02-24-2010, 07:48 AM   #6 (permalink)
Administrator
JWH_03_Dodge's Avatar
The headlights are controlled through the TIPM on the 07. Does he get the lamp out indicator or just no lights at all?
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline   Reply With Quote
Old 02-24-2010, 07:04 PM   #7 (permalink)
smokin6spd's Avatar
we found out today it was the cluster went bad i had a buddy from chrysler come to my shop and he knew what it was right away. thank you for all the help i appreciate it im going to get the exact reason why and post it
Old 07-10-2010, 01:23 PM   #8 (permalink)
Kilroy
Ever post the solution to your problem?
2004.5 CTD, 3500, SRW, LWB, 4x4, quad cab, auto, 4.10, PAC-Brake air bags,
Ute aluminum flat bed, Alaskan camper
Kilroy is offline   Reply With Quote
