Cross drilled rotors and pads - Dodge Cummins Diesel Forum
Old 05-22-2007, 10:39 PM   #1 (permalink)
aquaholic's Avatar
I need to replace the brake pads on my truck. I am considering cross drilled rotors and pads. Does anyone have a suggestion on what brand and were to get?
2004 Quad-cab short bed, 305ctd, 5" straight pipe, EDGE EZ, AFE intake, FASS 150, Turbo silencer permanent vaction, Nitrogen inj PROCOMP 305/65/17 on 10" MICKEY THOMPSON'S, RANCHHAND bullnose wench mount bumper
aquaholic is offline   Reply With Quote
Old 05-22-2007, 10:43 PM   #2 (permalink)
porkchopexpress's Avatar
cross drilled rotors will wear out your pads much faster... leave them to the high performance cars and high performance car wannabee's (ricers)
or if your stubborn, you can cross drill your own rotors and save a buck
maybe find some rotors off a wrecked truck or something to practice on/use
07 3500 4dr DRW 4x4 auto...
porkchopexpress is offline   Reply With Quote
Old 05-22-2007, 11:04 PM   #3 (permalink)
aquaholic's Avatar
Nice perspective, but what about pads that have good life and won't turn everything black?
Old 05-22-2007, 11:15 PM   #4 (permalink)
gstanfield's Avatar
I'm personally pretty found of the perfomance friction pads. They seem to stop better and last longer than any other brand I have tried. I buy them at autozone and they have a lifetime warrenty.
George
1997 2500 ext cab long bed 4x4 Boost control elbow, BHAF, KDP tabbed, 3k gsk kit, dodgezilla hybrid turbo, Z-series gauges, 47RE built w/valve body & converter, #100 plate.
gstanfield is offline   Reply With Quote
Old 05-23-2007, 11:29 AM   #5 (permalink)
bcfitzsimons's Avatar
Cross drilled rotors supposedly have a much higher chance of cracking than regular rotors. What you may want to do is look into slotted rotors instead of cross drilled. Look at Summit Racing's catalog-I think they actually have some slotted rotors that fit our trucks-
HTH
2006 2500 CTD Quad Cab Short Box Big Horn 4X4
2" KORE leveling kit, 35" Mickey Thompson MTZs on MT Classic II Wheels
Autometer Pyro, Boost, FP, Oil Pressure, Tranny TempTranny Work by Wally and Ollie at FTE
bcfitzsimons is offline   Reply With Quote
Old 05-23-2007, 11:43 AM   #6 (permalink)
Ditto on sloted.
Pete
2004 Laramie, 4x4, QC, 48RE, 3.73, SRS, Molten Red, BFG 285s, xfer and fuel tank skid plates, Frontier back bumper, Cool Blue (removed), Moog greasables, Defiant sector plate, FASS-150, billet TC and performance VB w/Sonnex, Yaesu 2M and CB radios, Nav 1, Rokk sens.
xploretx is offline   Reply With Quote
Old 05-23-2007, 12:24 PM   #7 (permalink)
MOPAR MAN's Avatar
I think on our heavy trucks sloted would be your best bet. Cross drilled rotors on our heavy trucks have a much higher chance of cracking. espechaly if you are towing and go thrugh a puttle or they get wet when there hot.
FOR SALE: 00 2500 4x4 5spd, Balanced&blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT,GT3788R, 120HP stix,FASS,ValAir DD,Fluidamper.
MOPAR MAN is offline   Reply With Quote
Old 05-23-2007, 12:35 PM   #8 (permalink)
Roid's Avatar
How does a rotor crack/break?
if anything the cross drilled holes should let the hot gass escape and allow the rotor to keep cooler.
03 2500 SLT, more candy than a pedophile's van
Roid is offline   Reply With Quote
Old 05-23-2007, 12:46 PM   #9 (permalink)
MOPAR MAN's Avatar
They do discapate heat faster. But thay are also not as strong. There is less surface ariea. You get them real hot and they will start cracking between the holes.
Old 05-24-2007, 11:32 AM   #10 (permalink)
Yeah where the cracks start to form is around the drill holes. Drilling weakens the surface of the rotor because there's not as much mass to the rotor surface, yet it still has to "stop" a truck of the same weight.
It's sort of like trying to suspend something heavy with a piece of paper-if the piece of paper's complete (no holes, no tears), it can hold a fair amount of weight above it. But once you start punching holes in the piece of paper, any weight you put on it makes it tear a lot easier. When it comes to cross-drilled brake rotors, this means
Old 05-24-2007, 12:12 PM   #11 (permalink)
Roid's Avatar
Problem solved!
This is a materials problem. Regular rotors are made from gray steel, which is weak crappy steal. Some spin offs of cross drilled rotors are just regular gray steel with holes; i could see gray steel cracking cause its junk metal, but not a set of rotors from EBC Brembo Bear etc cracking...
Old 05-24-2007, 12:24 PM   #12 (permalink)
UNDERCONSTRUCTION
99cumminsho's Avatar
I would go with a set of slotted/dimpled rotors and some good bendix semi-metallic pads. as far as brand for the rotors i have no idea im not much of a brake man i got my rotors of ebay they work real nice made a noticable difference.
1999 2500 ext. cab 4x4, auto., 4:10 gears. Currently under construction build thread coming soon
POWERED BY: FARM BOYS DIESEL
99cumminsho is offline   Reply With Quote
