air bag light on, turn signals messed up - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 06-19-2017, 07:54 PM Thread Starter
hoits27's Avatar
I have a 2006 2500 with only 60k miles, the air bag light just came on and the blinkers are really whacked. Even when using the hazards instead of a left or right blinker they blink at random intervals or stay on then go off or rights on when the left is off. I did a little search and found one possibility of the clock spring...any other ideas? I never brought it in for the airbag recall yet either.
2006 2500 QCSB | G56 w/ Valair Triple | 5" tbe | AFE ProDry | Banks TechniCooler
EFI by Anarchy | CTS Insight | Fass 150 | ARP | Hamilton Springs
Caltracs | Carli Front End | Bilstein | Fuel Hostage | 295/70R18 Toyo A/T II's
hoits27 is offline
post #2 of 3 (permalink) Old 06-19-2017, 08:02 PM
DodgeMech's Avatar
that recall won't fix a light, unless there's an actual internal problem inside the airbag causing it...which is rare
i wouldn't be surprised if it were the clock spring...they tend to get wore out
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #3 of 3 (permalink) Old 06-20-2017, 02:38 PM
kyle40367's Avatar
If your clockspring is broken the airbag light goes on. If the recall replaces the clockspring you're light should go away.
As for the turn signals, maybe your signal switch assembly is messed up and causing the issues.
2004.5 2500 HO QCLB ST 4WD 4" Turbo Back Straight Pipe, Smarty S-06, Pusher Intake Elbow, S&B Intake, XDP Grid Heater Delete, Inglewood Transmission Built 48RE, 3" Carli 2.5 Performance, Carli Torsion Sway Bar, Fass Lift Pump, 35s, Tint, GlowShift Gauges
kyle40367 is offline
