CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 12-16-2009, 06:48 PM   #1 (permalink)
06ramsprt's Avatar
Block Heater Cord Installation, Help!! Pics
I have an 06 ram 2500, and went ahead and got the block heater cord cause mine did not come with one. I, an idiot when it comes to diesels(since this is my first one) can not find the location to plug it in to the truck. I need some help finding the location. Please help, Pics would be all so great, to see how you guys routed it. Thanks in advance.
06ramsprt is offline   Reply With Quote
Old 12-16-2009, 07:26 PM   #2 (permalink)
Airsick's Avatar
In the picture right behind the oil filter housing you will see an orange rubber boot, that is the block heater cable. I think there is a little plastic cap over the plug in but I don't remember as I did mine quite some time ago. Sorry it's not the best picture of what you are asking but it is the only one I could find that had it in the picture. Hope that helps.
2007 QuadCab 2500 4x4, 6Speed, Inferno Red.
1996 Ext. Cab 3500 4x4, Auto
Airsick is offline   Reply With Quote
Old 12-16-2009, 07:26 PM   #3 (permalink)
Camsmell's Avatar
the cord plugs in underneathe your exhaust manifold and next to the oil filter it has a black screw on cap you need to remove for the plug to go in
07 5.9 mega cab fabtec lift XD rims with 35's s&b intake power puck ts shiftmaster 5" TBE Autometer Boost, pyro, Trans 2nd gen intake
Camsmell is offline   Reply With Quote
Old 12-16-2009, 10:50 PM   #4 (permalink)
dieselingwithnomoney's Avatar
Holy Fricken Crap Batman!!!!! Somebody Has Stolen Your Exhaust!!!!!!!
06 2500 QC, Edge JWA HOT, DDP 90's, 2nd gen manifold w/ Jacobs exhaust brake, SPS 62, 5" FBD exhaust Str8, Banks High Ram Intake, BAHF, leveled, Firestone Ride-Rite system, Goerend tranny with billet goodies , Devil's own.
dieselingwithnomoney is offline   Reply With Quote
Old 12-17-2009, 06:40 AM   #5 (permalink)
06ramsprt's Avatar
Found it!! Thanks guys!
Old 12-18-2009, 07:07 AM   #6 (permalink)
06ramsprt's Avatar
Ok, located block heater cord.....next question...how in the world do I get to it?? I ordered a kn air intake and am installing it today. Does that help me get to it? Or is there more disassembly needed. Thanks.
Old 12-18-2009, 07:32 AM   #7 (permalink)
I just did this the other day when my AFE came in. It is much easier to get to with the stock intake removed otherwise it takes some work to get you hand in there. Is you KN just a filter or is it a full cold air system? If it is a full system then when you take out the stock intake install the cord prior to installing the KN system. This allows you to look at where you want to run the wire much easier.
2006 2500 MCSB: 8" lift, 37" Toyo M/T, 22" XD, 5" TBE Straight Pipe, AFE Stg 2, Silencer Ring M.I.A
Implse1 is offline   Reply With Quote
Old 12-18-2009, 01:55 PM   #8 (permalink)
tryNto's Avatar
crawl under the truck and install from there...
2003 QC 2500 SLT HO CTD 6 spd 3.73 LS 4x4 LB Atlantic Blue, K&N CAI w/ S&B oiled filter, 4" TB Str8 pipe w/ 6" tip, ProComp Shocks, Quad ADR/Pulse, "Pusher" Intake Horn, Adj. Boost Elbow, Autometer EGT & Boost gauges, GDP 2mic Filter
tryNto is offline   Reply With Quote
Old 12-18-2009, 02:15 PM   #9 (permalink)
Super Moderator
TrueValue Truck's Avatar
No picture....but it's on the bottom of the block....just behind the oil filter. It's just as easy to lay on your back and reach it from underneath....if there has never been a cord on it , there will be a black plastic cap threaded on the plug location.....just unscrew the cap and screw the block heater cord nut on....route the wire up front and your done.
2010 3500 Reg. Cab C&C 4X4; G56 ;H&S Black Maxx; DFP Delete; EGR Delete
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
Old 12-19-2009, 08:48 PM   #10 (permalink)
True Vaule Truck described the location very well. I did mine from underneath and it took a little wiggling to get the plug in then the lock nut on, but it only took a few minutes.
Dave
2006 2500 Laramie 4x4 - K&N Filter, Edge Juice w/Attitude, Aero Turbine 4040, AirDog II, Pusher, Load Lifter 5000, Daystar.
davewright92 is offline   Reply With Quote
Old 12-19-2009, 08:58 PM   #11 (permalink)
D45
D45's Avatar
04 QC/LB, 4WD, 305/555 HO CTD, 37x12.50/H2s, Fabtech 4.5" Lift, Radflo Steering Stab, PSC Steering Brace, MBRP 5" Straight Pipe, CFM+, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Super B Single Turbo, SMARTY SR POD, ARP Studs, Built 48RE Trans
D45 is offline   Reply With Quote
Old 01-02-2010, 04:18 PM   #12 (permalink)
MattH's Avatar
Thanks for the info. My cord should be hear soon
--- 2005 QCLB 3/4T Laramie ---
MattH is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
