Intake Air Heater Codes! Help!! - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 11-18-2009, 10:54 AM Thread Starter
Vigilante
05pscc's Avatar
Started the truck yesterday and check engine light came on. Checked codes with Smarty and there were two of them. They were P2609- No voltage drop seen from intake air heater and P0542- High voltage on the #1intake air heater relay. After checking the codes I noticed that my grid heater is not cycling.
Has anyone had this problem and are there any ideas to fix it or were to start looking. EDoes the heater have it's own fuse?
Thank in advance for the help guys!
2003 Chevy Tahoe, stock everything, 37,000 miles and counting, slowly!!
SOLD-2006 Mega Cab!!!!!!!!!!!!
05pscc is offline
post #2 of 11 (permalink) Old 11-18-2009, 11:06 AM
rbmorgan's Avatar
Take the wires off the grid heater,clean them and then put them back on just a little tighter than they were.Clear the code and you should be ok. I had the same problem but I was lazy.I didnt take the wires off and clean them I just made it a bit tighter.It sucks workin on a truck in -30! Hope this work for ya
06,Ram 3500,afe air stage 2,ats in and out manifolds,Aurora 3000 turbo/w boost fooler,custom 5" ex/w jake brake,smarty s06 pod set @ WFO,valair 600hp clutch,auto meter boost and egt gauges,dashdaq monitor.
rbmorgan is offline
The Following User Says Thank You to rbmorgan For This Useful Post:
05pscc (11-19-2009)
post #3 of 11 (permalink) Old 11-18-2009, 11:21 AM
iccmiller's Avatar
The 2 intake manifold air heater relays are located in the engine compartment. They are attached to a common bracket. This bracket is attached to the right battery tray.
Check the wires going to the relays and make sure that they are tight and not corroded.
04, Laramie 4x4 QCLB, Directionals in the Mirrors, Smarty SO6 POD, ISSPRO EGT/Boost/Tranny Temp, Quadzilla RP Gauge, Air horns, Boost Elbow, Airbox Mod, 2nd Gen intake, Diamond Eye 4" turbo back, Lost kitty "23 Years US Navy Chief"
Hypertech III for 2004 Dodge Ram Diesel for sale
iccmiller is offline
The Following User Says Thank You to iccmiller For This Useful Post:
05pscc (11-19-2009)
post #4 of 11 (permalink) Old 11-18-2009, 11:25 AM
06 Cummins
iTrader Score: 5 reviews
Check all your wiring and clean the IAT sensor. The sensor is partially responsible for your grid heater info to turn on the grid heater, if the sensor is dirty you will get the codes you have gotten as well.
CD
2006 Dodge 3500 MC DRW 4x4 6-spd 3.73 LS rollin' on 19.5's. Not stock by any means . .
CD in NM is offline
The Following User Says Thank You to CD in NM For This Useful Post:
05pscc (11-19-2009)
post #5 of 11 (permalink) Old 11-18-2009, 11:30 AM
ces139's Avatar
CD in NM
Where is the "IAT sensor" located at?
Black '06 2500 G56 4x4 Mega Laramie, debadged, 3" Carli 2.0 running on 35" Toyo OCs, Smarty S06 PoD, Banks Ram-Air Intake w/Super Scoop, Airdog FP100, BD Pulse Manifold, Amsoil BMK25, ISSPRO EV = Pyro, Boost, & Fuel Pres. (almost dechromed)
ces139 is offline
post #6 of 11 (permalink) Old 11-18-2009, 11:54 AM Thread Starter
Vigilante
05pscc's Avatar
Quick fix!! The two little wires that push down on the posts on the relay were off. Right next to the passanger battery. Don't know how in the heck they both just popped off, but the heater is cycling again and no codes!! Thanks guys!!
05pscc is offline
post #7 of 11 (permalink) Old 11-29-2009, 05:32 PM Thread Starter
Vigilante
05pscc's Avatar
Codes came back a couple days ago! Decided to do deeper troubleshooting. Took my air box off and found the brown and yellow wire, coming from the relay, almost in half. Little splicing and electrical tape along with routing the wires a little different and we are good to go. No more codes and grid heater is cycling normal again!! I am so prouod of myself!!
05pscc is offline
post #8 of 11 (permalink) Old 11-29-2009, 05:42 PM
ruidosododge's Avatar
haha good deal man!
'12 VW Passat Previous Rams: '10,'06,'04,'01
ruidosododge is offline
post #9 of 11 (permalink) Old 11-29-2009, 05:48 PM
Buck08's Avatar
There ya go! Cheap fix too!!!
10 Laramie C/C Shotbox
02 Excursion Limited TS 6 pos
95 2500 2wd project
Buck08 is offline
post #10 of 11 (permalink) Old 11-30-2009, 03:38 AM
glad you got it fixed..
what would i need to do if it actually said the opposite, grid heater intake 1 low? i know its a code on here, and one im havin on my 3500.. truck starts up just fine, and i can hear grids cyclin.. kinda makes me ignore it a bit for that reason..
on another note tho...
is that where the barometric sensor goes?
thanks for any help fellas..
Rick
05 3500 QCLB 4x4
95 5 spd RCLB 4x4
thanks VALAIR INC CLUTCH!!
TxDiesel007 is offline
post #11 of 11 (permalink) Old 12-01-2009, 11:22 AM
mornin guys, mornin bump...
thanks for help
05 3500 QCLB 4x4
95 5 spd RCLB 4x4
