Old 11-06-2009, 11:04 PM   #1 (permalink)
Overhead Console Install
My truck never came with a overhead console, is it possible to install one? Is the wiring for it their in the headliner? Do i just buy the console plug it in? What holds it up on the headliner?
Thanks
2004 Dodge QuadCab 4x4 3500 LongBed85 Hp Predator Plug N Play,SP Boost Fooler,Bully Dog Power Pup, Ride Rite Air Bags,2" Leveling Kit,Cragar Soft 8 Black, Shift Glow Boost,Pyro,and Trans Gauges.Triple Disc Torque Converter,Transgo Shift Kit,
Flanman55 is offline   Reply With Quote
Old 11-07-2009, 12:42 AM   #2 (permalink)
overhead console
You will need the console ,The wiring harness, Here's the biggy! Need the female connection uner the dash, If you have none there, try to find that wiring system at a junk yard, there's a fellow on this site, if you look up the members list, he is always parting out trucks. ODIEUB to look for.
1994 12 valve 4X4 2500 Loaded Carli Suspension featureing 3" Kings Full billet Suncoast trans converter & flex plate HX 40 370 injectors -Snow Performance Meth h20 injection- gov springs- ATS manifold- AFE sock 315-75-16 Pro-Comp Extremes Wilco
Grumpy John 4X4 is offline   Reply With Quote
Old 11-07-2009, 08:01 PM   #3 (permalink)
So i need a wiring harness and the console. Where do i plug it into?
And how does the console mount to the headliner?
Old 11-08-2009, 12:45 AM   #4 (permalink)
Talking console
You need to start going to junk yards to find the parts you need! The female connection and that wiring you will not have, once you see the console and wiring harness's and connection female, yo0u will know how to install, try 270-230-3317 thats ODIEUB He is the gut that parts out many trucks!
Old 11-08-2009, 01:01 AM   #5 (permalink)
guinness765's Avatar
about the headliner... it comes down pretty easy.
start at the front IMO take the grab handles off the pillars then pull out the pillars
take off your overhead cab light
then take the handles of the middle pillars (or move to back pillars if you have single cab) take off pillars...its all kinda self explanatory as you start doing it just find out what holding you up and take it off but support the front of the headliner as you move back
05, 2500 5.9L HO. Quad Cab SB 4x4 straight piped, AEM intake, silencer ring MIA, smarty jr, leveling kit, 33's, custom front skirt and side rail lights,airhorn
guinness765 is offline   Reply With Quote
Old 11-08-2009, 08:41 AM   #6 (permalink)
navman28's Avatar
Do they also make just a cover with the lights? I would like to remove the lie-o-meter, but keep the lights.
06 2500 5.9 QC 4x4, 48RE, K&N, MBRP Dual Exhaust, 35" Pro Comp Xtreme AT, 3" TGC Lift, Smoked Recon Cab Lights, MP-8, Street Scene Grill, ISSPRO EV2 Pyro, Trans Temp, Rail Pressure Gauges
navman28 is offline   Reply With Quote
