Old 11-05-2009, 09:59 PM   #1 (permalink)
Trailer lights
My truck is an 03 3500, I am having a problem with the trailer lights, on both my flat bed and covered trailer. I'm pretty sure the issue isn't with the trailers, given the fact that they worked fine with my old dodge truck & neither work now. The trailer brake shows the trailer connected. Any suggestions?
Another request for information, would any have or know where I can get a drawing for the electrical connection? Where the trailer plugs into the truck.
Thanks,
Jerry
Jerry
Jerry Ray is offline   Reply With Quote
Old 11-05-2009, 10:21 PM   #2 (permalink)
cummins04's Avatar
check fuse 33 under hood for running lights
04.5 quad cab short box, 3805 superchips, mp-8, 2 inch leveling, 4" to 6" aussies, silencer ring mia, modified air box,smoke switch Never ending process----
cummins04 is offline   Reply With Quote
Old 11-06-2009, 11:29 AM   #3 (permalink)
Hoffa_49r's Avatar
95% of trailer light issues that I have experienced are with the ground wire problems. Try checking the ground terminal on your truck and check where the wire grounds to your truck. May be the ground wire is broken somewhere on your truck.
'04.5 2500 QC, SB, SLT, auto, 4x4, 3.73
41" Donaldson w/CAT MIA & 5" custom tip, 2nd gen intake horn, smoked RECON cab lights, SRT-10 pillar pod w/Dipricol pyro
Hoffa_49r is offline   Reply With Quote
Old 11-06-2009, 12:14 PM   #4 (permalink)
guinness765's Avatar
I completely agree. i spent days trying to figure out why my trailer lights were doing crazy things. in the end it was a grounding issue, in my case the ground on the trailer
05, 2500 5.9L HO. Quad Cab SB 4x4 straight piped, AEM intake, silencer ring MIA, smarty jr, leveling kit, 33's, custom front skirt and side rail lights,airhorn
guinness765 is offline   Reply With Quote
Old 11-07-2009, 06:46 AM   #5 (permalink)
Thanks for the input. I will check the ground. The fuse is good.
Jerry
Jerry
Old 11-09-2009, 03:11 PM   #6 (permalink)
added information
Looking for a drawing where the tailer connects to the truck.
Thanks,
Jerry
Jerry
Old 11-09-2009, 03:22 PM   #7 (permalink)
rpage's Avatar
heres the color codes for most plugs, tm- brown, rt-green lt -yellow, a/s blue, gd is black or white
rpage is offline   Reply With Quote
Old 11-09-2009, 03:39 PM   #8 (permalink)
See if you have power at the plug in on the truck....you might not. If so it could be the lighting module under the fuse box. This was the case with my buddy's 03 and the case with my tail light (also an 03). My $0.02.....just wire around the problem with a relay, etc rather than spend hundreds replacing the junk computer.
'03 2500 QuadCab 4x4, Banks SixGun, Smarty, 5" Straight Pipe, AFE Stage 2, Banks Intercooler, Dunrite VB-Triple Disk-Flexplate-Billet Shafts, Snow Perf. MPG-MAX water/meth, Airdog 150, DiPricols,....90s, 425s, Arson3, and Wicked Stocker/S400 on the way!!!!
StillTooSlow is offline   Reply With Quote
Old 11-09-2009, 03:59 PM   #9 (permalink)
Thanks for the information. I don't understand why dodge invest so much time and money into a truck with this ability and then cuts corners.
Jerry
Old 11-10-2009, 01:18 PM   #10 (permalink)
Greatsoil LLC's Avatar
i have the lamp out sign on my dash panel and i cant seem to figure it out, i checked all the fuses and also replaced any bulb that was out and still the lamp out remains on. i think its maybe the flasher relay itself is out or half bad but cant find it anywhere! any assistance would be appreciated
2003 Ram dually 3500 crew cab
everything stock
Greatsoil LLC is offline   Reply With Quote
Old 11-10-2009, 07:42 PM   #11 (permalink)
Thanks for the suggestions. Ground issue fixed.
Jerry
