Old 11-03-2009, 03:52 PM   #1 (permalink)
Is it worth buying a 3rd gen?
Well yesterday I sold my 94 2500 4x4, it was a great truck but the rust really got it. It had 524,000km on it and worked great. I need to replace it with something right away but I have been doing some reading on the forum and it sounds like the common rail trucks can have alot more problems than the old trucks. I would really like a bigger cab so the 03 and up is kind of my only option. I have a chance to buy my friends 05 with a 6-speed, 290,000km new hubs, clutch and the trans was just gone through. I just dont want to buy it and have some major fuel or engine issues. Is 05 a good year to get? Maybe I should just keep my eyes open for a good 01 or 02? Thanks for the help and suggestions, this is a great site!
lt4tyrell is offline   Reply With Quote
Old 11-03-2009, 04:01 PM   #2 (permalink)
03 Cummins
twhetten's Avatar
The 3rd gens are great trucks, I would much rather have one then the 2nd gen 24valve, for the comfort alone. Most people that are having injector problems are running pressure boxes, and with these trucks filtration is the key to keeping injectors alive. Get a good filtration system like and airdog or a Fass and you will be good to go.
Ty-2003, Red, Dually, HO, NV5600, Edge EZ, Airdog, Smarty,Jammer 90s, Full CAI, Capped Rail, water/meth, Valair 3600 DD, pacbrake, full rack-o-gauges, Dual Bull Hauler Stacks, Ranchhand Full Front Replacement, Hauler Bed 482hp/1078tq on 6/6/09 w/o jammers
October Cumminsforum ROTM Winner
twhetten is offline   Reply With Quote
Old 11-03-2009, 04:34 PM   #3 (permalink)
Gsxguy's Avatar
Id rather have a third gen myself. They are nice trucks. One downfall to an 05 is they have plastic endtanks on the intercooler, but thats easily fixed through a aftermarket Ic or an Oem from a diff year.
2006 Dodge Cummins, 6 speed, 4x4, Ats compounds, Ats dual cp3's, Ats arc flow, Ddp 120s, Arp studs,SBC 3850,5 inch Tbe,6" Lift, 20x12s w/35's, alot of other stuff that wont fit in my sig
Gsxguy is offline   Reply With Quote
Old 11-03-2009, 04:41 PM   #4 (permalink)
Ok thanks guys, where is the inline pump on an 03? I also might be going to look at it but I was just wondering how I can quickly tell if it has been replaced with an in tank one under warranty.
Old 11-03-2009, 04:49 PM   #5 (permalink)
Gsxguy's Avatar
Im not sure what you mean by your question. If it has the stock lift pump it will be in the tank. No real good way to tell if its been replaced. You can either drop the tank or take off the bed and look.
If you are talking about the Cp3 injection pump that will be in the engine bay on the driverside. If thats been changed you could always ask for a receipt. You can ask for a receipt on either one I guess.
Old 11-03-2009, 04:52 PM   #6 (permalink)
03 Cummins
twhetten's Avatar
bump the starter and dont start the truck but leave the key on, the lift pump will run for 30secs, you can hear where it is coming from. The 03s had the pump in the engine but alot got the intank one put in later.
Old 11-03-2009, 05:12 PM   #7 (permalink)
ok perfect i will try that thanks
