Old 11-01-2009, 06:51 PM   #1 (permalink)
Interior Lights Flicker after gauge install
After I installed my Isspro Pryo the dome light and console lights flicker when the door is open. Any Ideas on a cause. When I connected the dimmer wire from the gauge to the switch I used the wrong orange/brown wire first but re-solder it back together. Is a bad solder connection potentially to blame?
Thanks
-Steven
05 4x4 Big Horn Edition CTD G56
315x70 Dune Grappler DT, Smoked Cab Lights, Smarty S04, Isspro Pyro, Gutted Cat, Straight Piped with 4" Duals, Gutted Torque Tube, Silencer Ring MIA
sward is offline   Reply With Quote
Old 11-04-2009, 04:50 PM   #2 (permalink)
anybody have any thoughts....
Old 11-05-2009, 06:13 AM   #3 (permalink)
Dodgezilla's Avatar
Pop the switch back out of the dash and try wiggling the wire and see if it affects it any. If so, then you found your cause. Otherwise one of your other connections may need attention....
04 Ram 2500 305/555 HO,48RE,4x4,3:73s,QC,LB,Infinity sound,MOPAR DVD,Green /Silver,PW Wheels,4"exh w/ 6.7l+BullyDog mufflers,Timbrens,Bilsteins,VA C3.2,DS Predator,Westachs,Fumoto,BHAF,2nd gen intake,HE351,ImitationTrainHorn,TRM, 16" pusher fan
Dodgezilla is offline   Reply With Quote
