reverse lights - Dodge Cummins Diesel Forum
Old 10-28-2009, 03:35 PM   #1 (permalink)
03FF's Avatar
reverse lights
Hey guys
I would of put this in technical place but i do not have access it it.
My question is how do i hook up lights that will come one when i put my truck in reverse. Do i got to put a wire in my fuse panel or what?
Or is it just better to run them off a toggle switch
03FF is offline   Reply With Quote
Old 10-28-2009, 03:38 PM   #2 (permalink)
Bow Chicka Bow Wow
Brentc's Avatar
Easy to just tap into the reverse wire.
Easy way is to take the tail light off and look at the power cable, trace it down and tap into it for your power and you backup light will come on auto when the truck is put in to Reverse
2012 Laramie Longhorn
6" Long Arm BDS, 37" Toyo MT's, 20" BMF R.E.P.R. Wheels
Brentc is offline   Reply With Quote
Old 10-28-2009, 03:43 PM   #3 (permalink)
15 Digger's Avatar
There are adapters to tie into trailer wire harness if you have it. If not and you use powerful lights you can tap reverse wire to control a relay that is fed by battery.
06 QC 2500, auto, 4:10, Mineral grey, intake baffle delete, muffler delete, 2in level kit/with Bilstein 5100, Diamond Back bed cover and diamond plate side steps, more to come $$$$.
15 Digger is offline   Reply With Quote
Old 10-28-2009, 03:59 PM   #4 (permalink)
rook1322's Avatar
I just tapped into my reverse light wiring...Quick simple and easy
2005 Dodge Ram 2500 Sport 6-speed with a few bolt-ons --Thanks AMJ Performance for helpin with the tweaks, and Jonathan at Bean's for the dyno runs!
637.7 HP 1360 FT. LBS Torque
rook1322 is offline   Reply With Quote
Old 10-28-2009, 10:48 PM   #5 (permalink)
tj_brockman's Avatar
I ran mine off a switch in the cab, so when I am working behing my pickup at night I can just leave them on without having to kill the engine.
06 5.9 CTD 6 speed 2500 QC LB 4X4 - Front & Rear Diamond B replacement bumpers - B&W Goosneck - Homemade Turbo Back Exhaust - Silencer Ring MIA
tj_brockman is offline   Reply With Quote
Old 10-29-2009, 12:28 AM   #6 (permalink)
TECH SPECIALIST
underramarmor's Avatar
2004 Silver Srt 4 Stock
2005 Black Ram 2500 5.9l 2wd Auto
2007 Blue Ram 2500 6.7l 4wd Auto
underramarmor is offline   Reply With Quote
The Following User Says Thank You to underramarmor For This Useful Post:
SlVRbullet (10-29-2009)
Old 10-29-2009, 12:29 AM   #7 (permalink)
TECH SPECIALIST
V-LEDS HIGH POWER 18W LED BACK-UP LIGHT LICENSE PLATE FRAME
Old 10-29-2009, 09:11 AM   #8 (permalink)
BC Chapter President
Fisherguy's Avatar
If you're adding some back up lights just tapping into the factory wiring will not give you enough current cuz of the fine gauge of the wiring, whatever lights you hook up will be very dim, best to use a relay like shown above.
I used a 3 way switch, 1 pos'n to come on automatically when I put it in R, 1 pos'n off and the third pos'n on manually so I can have them on when the trucks running, handy when hooking or unhooking a trailer.
06 QC 3500, DiPricol; S&B CAI; Smarty Revo POD; Quad X2: Pac Brake PRXB/air bags & Airlift Wireless controller; AD 100/Liberty canister: 4 KC's on RED bar; SB OFE; Kore; Thuren coils; Bilsteins; 285/75R18 Toyo AT2's on 18x9 Level 8 Strike8's; ATS lares; DuraFlaps; PP CA's; BD steering brace & track bar; 07 Komfort 274TS
My pics
Fisherguy is online now   Reply With Quote
Old 10-29-2009, 08:35 PM   #9 (permalink)
rook1322's Avatar
I hooked up the small $14 foglights from wally world on mine, straight into the factory wiring and they are BRIGHT and I didnt use a relay.
Old 10-29-2009, 08:40 PM   #10 (permalink)
TECH SPECIALIST
good luck with that//...
Old 10-29-2009, 08:46 PM   #11 (permalink)
Fisherguy's Avatar
Yup, I tried that too on my old Ford, they were only about 50% the total brightness compared to when I added the relay.
My pics
Old 10-29-2009, 08:50 PM   #12 (permalink)
TECH SPECIALIST
that is bc that circuit was really meant to power up that... just a few lil 3w bulbs im sure the wire was getting hot... what where the watts on the extra lights added.. 15 watts a peice
