air bag light is on... been on for a while, used to ding all the time, only dings when i start the truck now. dont want to go to the stealership and pay big money to get it fixed. anybody now how resolve this. i have looked at the 2 fuses in the fuse box with the yellow tabs over them they are fine. dont know what else to do.
04.5 Cummins QC, 4 in. lift, Toyo 35's Mud, Edge Juice W/ Attitude, MPRB 4in, K&N Drop In Air Filter, Rebuilt 48RE Sun Coast, W/ Billet Input Shaft, Spec Rite TC, BD Flex Plate, Silencer Ring MIA, Intake Tube Hollowed, Smoke switch, Upgraded Steering. .
Yeah, I've seen clock springs go bad as well so if you have other components not working in the steering wheel that could be the problem. The airbag module I believe is similar to the ABS unit in the sense that you can't get codes out of the OBD-II port. I think short of having a dealer read the codes out of the module so you can narrow down your search you should check the fuses with a Meter (not just a visual inspection) it is going to be pretty tough to narrow down your cause.
2001 QCLB 3500 Dually 4X4, Stock, FOR SALE 8000 OBO
2003 QCLB 2500 640 HP / 1125 ft/lbs SOLD!
Parts for sale Van Aken SmartBox, Stage II Monster Pump, DPS 62/75 Twins, and FASS 95, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. Parting out 08 3500. http://www.cumminsforum.com/forum/07...-part-out.html.
Yeah, on mine the clockspring went bad. I new that, because none of my steering wheel controls worked. If they do work, you should be able to rule out the clockspring, and start the search from there.
Other things can work on your steering wheel with a bad clock spring. Or a clockspring that is going bad. Mine started with the Air bag light dinging. The cruise and horn still worked . Then the horn stopped, then the cruise. So just because your airbag light is going off and other things work, it could still be the clockspring. Anybody no if there is a DIY thread on here to install the new one?? I have looked but have been unseccesful!
2003 Chevy Tahoe, stock everything, 37,000 miles and counting, slowly!!
