Hey guys, I have a 05 2500, I noticed my cooling fan was not coming on, so I but one from Oreallys (around $200) after the install and first time starting the truck it worked, never heard the roar like that so I knew it was working, next morning I started the truck didn't hear it, ( I'm in MI. Where it's cold till June from some reason) so I checked the smarty touch DTC and sure enough there it was "cooling fan speed" I have checked the plug and all wires to assure I didn't get them wadded up in the fan and I didn't. I'm I to assume a "bad part"?? Any ideas would be helpful... Thanks!!
that is one part you should buy from dealer
the aftermarket ones don't work
allmoparparts,com is our sponser gives us deals
search on here in sponsor section
I'm not 100% sure on that, I do know it should kick when you first start your truck, and you'll know it's on cuz it's quite loud. (Roaring) I also wondered if the fact that I have a programmer that it is interfering in some way, because I was under the impression that the fan is controlled by the ECM.
I agreed.
The cooling fan would kick in when high side pressure was higher than 240psi increasing.
And I don't think the fan would kick in right the way once comp starts to run.
379.7K members
